Mobilize Power V2G Smart-Home-Integration, kostenlos und Open Source
Mobilize Powerbox Verso: charges, energy sent back, V2G hours, cost, V2G bonus, balance
Follow in Gladys the charges and the energy sent back by your car on a Mobilize Powerbox Verso with the Mobilize Power offer: charging cost, V2G hours gain, subscription and balance, per day, month and year.
Requirements
- A Mobilize Powerbox Verso on your local network (Wi-Fi or Ethernet), with a fixed IP address (set it in your router).
- The password of the installer account of the borne, printed on its label (user
installer).
The integration reads the borne read-only: it never changes its settings and does not interfere with Mobilize Power or the My Renault app.
Setup
- Configuration tab: the borne's IP address, user and password, then Test the connection to the Powerbox. Gladys hides the password as you type it: this button confirms it is right ("OK") or refused.
- Your contract's subscribed power (for the subscription).
- Discovery tab: create the "Mobilize Power V2G" device.
- Dashboard: add the V2G balance widget and pick the period (today, this month, this year).
Updating from version 0.1
Version 0.1 misread the car's presence (always "plugged") and declared features Gladys duplicated as "(consumption)" and "(cost)". After the update, delete the "Mobilize Power V2G" device (Devices tab) and create it again from the Discovery tab. The V2G hours estimated before the update are reset; the energy and the official hours you entered are kept.
The calculation
| Line | Calculation |
| Charging cost | kWh charged × price per kWh |
| Subscription | annual subscription × days of the period ÷ days of the year |
| V2G bonus | V2G hours × V2G Hour rate |
| Buyback of the energy sent back | kWh sent back × buyback price (0 by default) |
| Balance | charging + subscription − V2G bonus − buyback |
A negative balance is a gain.
The tariffs come from the grid published on mobilize-v2g.fr, read once a day (built-in fallback: the August 2026 grid). A value entered in the configuration always wins over the grid.
The V2G hours are estimated from the time the car is plugged in (Mobilize counts them only once the minimum charge level is reached and until the departure time). The car is detected on the socket's control pilot: a cable left in the borne without a car does not count. Enter the official figure of a month with the Official V2G hours button of the widget, or the action of the same name in the configuration.
Limits
- The borne's local API is not documented by Mobilize: a firmware update could change it.
- If the borne or Gladys is unreachable for more than 10 minutes, that time is not counted as V2G hours; the energy is caught up thanks to the borne's counters.
- Amounts are TTC (taxes included), computed with the grid prices: the invoice may differ slightly.
- In Discovery, Gladys shows a "$" icon for every currency feature whatever the currency: the amounts are in euros (unit €).
Diese Einstellungen fragt Mobilize Power V2G in seinem Konfigurationsbildschirm in Gladys ab.
| Your Mobilize Powerbox Verso | section | Nein | The integration reads the borne on your local network, read-only: it never changes its settings and does not interfere with Mobilize Power. The user and password are those of the installer account, printed on the label of the borne. Give the borne a fixed IP address in your router. |
| Powerbox IP address | string | Nein | |
| Powerbox user | string | Nein | |
| Powerbox password (installer account) | secret | Nein | Hidden as you type it: after saving, the "Test the connection to the Powerbox" button says whether it is right. |
| Read the borne every (seconds) | number | Nein | |
| Tariffs (TTC) | section | Nein | By default the tariffs come from the grid published on mobilize-v2g.fr, read once a day. A value you enter below always wins over the grid; leave it empty to follow the grid. The V2G gain is the V2G hours times the V2G Hour rate. The V2G hours are estimated from the time the car is plugged in: enter the official figure of a month from the widget or below. |
| Read the tariff grid on mobilize-v2g.fr | boolean | Nein | |
| Subscribed power | select | Nein | |
| Price per kWh (€, empty = grid) | number | Nein | |
| V2G Hour rate (€ per hour, empty = grid) | number | Nein | |
| Annual subscription (€, empty = grid for your power) | number | Nein | |
| Count the subscription in the balance | boolean | Nein | |
| Buyback of the energy sent back (€/kWh, 0 = none) | number | Nein | The Mobilize information sheet says the energy sent back is bought at the selling price; the V2G hours are the main gain. Leave 0 unless your invoice shows such a credit. |
So installierst du Mobilize Power V2G in Gladys
- Öffne in Gladys Integrationen: Mobilize Power V2G erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/gaetanb76/gladys-mobilize-v2g:0.2.0) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/Gaetanb76/gladys-mobilize-v2g.
Mobilize Power V2G benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Mobilize Power V2G ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von Gaetanb76 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
