Mitsubishi Heavy WF-RAC Smart-Home-Integration, kostenlos und Open Source
Mitsubishi Heavy WF-RAC-Integration für Gladys Assistant
Mitsubishi Heavy Industries air conditioners with the WF-RAC Wi-Fi adapter, over the local API.
This integration shows in Gladys the Mitsubishi Heavy Industries (MHI) air conditioners fitted with the WF-RAC Wi-Fi adapter (the one of the Smart M-Air app), through the local API of the adapter, without any cloud.
Never tested with a real device. The protocol of the adapter is not documented by the manufacturer: the integration follows pywfrac and its Home Assistant integration, and was only tried against simulated answers (built from real frames those projects published). Your feedback is welcome.
Unofficial, not affiliated with Mitsubishi Heavy Industries.
Not for Mitsubishi Electric: Mitsubishi Electric air conditioners (MELCloud) are handled by the MELCloud integration of the Gladys core.
One device per adapter (one per indoor unit), with:
FeatureGladys typeCommand
On/offair conditioning, on/offyes
Mode (automatic, cooling, heating, drying, fan only)air conditioning, modeyes
Setpoint (0.5 °C steps)air conditioning, setpoint (°C)yes
Fan speed (automatic, 1 to 4)air conditioning, fan speedyes
Vertical vane (swing, positions 1 to 4)air conditioning, vertical swingyes
Indoor temperaturetemperature sensor (°C)no
Outdoor temperaturetemperature sensor (°C)no
Error code of the unittextno
The setpoint is held to the range of the unit for the mode read just before: 16 to 30 °C in cooling, 18 to 30 °C otherwise; ZT models (2025) go from 10 °C in heating up to 33 °C in cooling and drying. In fan only, the setpoint is the one of the next mode: the range is that of all modes (16 to 30 °C, 10 to 33 °C on ZT). A value out of range is refused, never sent. A mode change brings the setpoint read into the range of the new mode and sends it with it (for example 10 °C in heating becomes 16 °C when switching to cooling).
Setup​
  1. Give each adapter a fixed IP address in your router (it often shows under a name made of its MAC address).
  2. In the configuration of the integration, enter the addresses, separated by commas (8 at most). The port is 51443; the integration finds on its own whether the adapter speaks HTTPS (tried first) or HTTP. The same adapter typed twice (IP address and name) is read once.
  3. Save, then add the air conditioners from the Discovery tab.
  4. To control them from Gladys, turn on Allow the commands.
Each adapter is read every 60 seconds (30 s to 10 min), one request at a time, one second apart at least: the adapter takes one connection at a time. After a failure, the adapter is read again after 30 s, 1, 2 then 5 min, never sooner than the interval; the Test the connection button keeps that delay and says when the next try comes.
Commands and the registration on the adapter​
Reading the state needs nothing. Writing needs Gladys to be registered on the adapter, which has only four slots (the Smart M-Air app of each phone takes one) and frees none on its own. Hence:
  • commands are off by default: without the option, nothing is registered on the adapter;
  • Gladys uses one identifier for the whole installation, written once in a file of its own in /data; if it cannot be written, Gladys does not register at all (each restart would take another slot). If that file becomes unreadable, it is set aside, Gladys makes no other on its own and the status says so: the Register Gladys on the adapters button makes a new one when you ask (the old slot stays taken, see "Uninstalling");
  • it registers once per adapter; after a refusal it tries again at most once an hour, never in a loop;
  • when the four slots are taken (the adapter counts four accounts) it no longer tries on its own: the status says so. Remove an app or a phone in Smart M-Air, then click Register Gladys on the adapters.
Each command:
  • reads the state of the air conditioner again just before, and is decided on that read only (the adapter receives a full state: a frame built on an old state would undo what changed since);
  • leaves within 3.5 seconds of the click, or is refused without being sent ("too slowly: not sent") when the adapter is slow to answer;
  • checks the "Allow the commands" option on arrival and right before sending;
  • is never sent again on its own. When the adapter does not answer after sending, the message is "Command sent, without confirmation": check the state a few seconds later (Gladys reads the unit again after 5 and 20 seconds);
  • is not sent when the air conditioner already is in the asked state;
  • is refused when the frame read cannot be verified (its CRC does not match), or when the adapter gives no fresh state (result 0);
  • is refused, unsent, when the previous command on another setting of the same air conditioner is not visible yet in the state read ("try again in a few seconds"): the frame would undo that command. Gladys never fills the state read in from its memory.
One command at a time per air conditioner: a second one, while a first one is running, is refused.
60-second lock. Each successful write keeps writing to its author (the device that sent it) for one minute; reads are not affected. So a Gladys command sent less than a minute after a change made in the Smart M-Air app (or another Wi-Fi controller) is refused ("try again in a minute"); Gladys neither waits nor tries again. The other way round, the app is refused for the minute after each Gladys command. The infrared remote does not go through the adapter and is not affected.
On/off and "turn everything off". As with MELCloud, on/off is an air-conditioning feature, not a switch. Depending on what exposes it (a voice assistant, HomeKit, Google Home, MCP…), a "turn everything off" may reach the air conditioner: check your scenes and assistants if you do not want that.
Changing the mode does not switch on an air conditioner that is off: only the mode changes.
Known limits​
  • No horizontal vane, 3D auto, self-clean, Home Leave mode, external room temperature, operation data nor energy in this version.
  • On some units (old bus signature), the adapter does not report the horizontal vane position nor 3D auto: like pywfrac, each command then sets them back to automatic / off.
  • A value that cannot be read (a setpoint outside 10 to 33 °C, a temperature sensor absent or cut) is left unknown, never published.
  • When the adapter is slow to answer (more than 2 to 3 seconds), commands are refused without being sent. Try again; tell us if it happens often.
  • One Gladys installation per adapter is expected.
Uninstalling​
The slot Gladys takes on each adapter stays taken after uninstalling: this version has no button to free it yet. Before uninstalling (or to free the old slot after an unreadable identifier file), remove the matching entry in the Smart M-Air app if it shows it (not checked: a client registered locally may not appear there). Otherwise a reset of the adapter (see its manual) should empty its account table (not checked); the phones then have to be paired again.
Security​
The local API has no password: any device of the local network can read and, once registered, control the air conditioner. Keep the adapters on a trusted network (a guest network or a dedicated VLAN is a good idea).
Depending on its firmware, the adapter speaks HTTP or HTTPS. Over HTTPS its certificate is self-signed and its TLS stack very old: the integration does not check the certificate and accepts TLS 1.0 and later, OpenSSL security level 0 and legacy renegotiation. This does not protect against a device impersonating the adapter on your network. Over HTTP (the oldest firmware), everything travels in plain text on the network, the identifier of Gladys included.
The identifier of Gladys (operator and device) is kept in /data, never written to the logs, and sent only to adapters already identified: the first request to an address (which recognizes the adapter) carries a placeholder identifier.
Credits​
The protocol is ported to JavaScript from pywfrac 0.1.10 and the Home Assistant integration Mitsubishi-WF-RAC-Integration (jeatheak, blues-sechseck, MIT license), whose reference of the WF-RAC module guided this work. See THIRD_PARTY_NOTICES.md.
Diese Einstellungen fragt Mitsubishi Heavy WF-RAC in seinem Konfigurationsbildschirm in Gladys ab.
Your Mitsubishi Heavy Industries air conditionerssectionNeinShows the Mitsubishi Heavy Industries (MHI) air conditioners fitted with the WF-RAC Wi-Fi adapter (Smart M-Air app) in Gladys through the local API of the adapter, without any cloud: on/off, mode, setpoint, fan speed, vertical vane, indoor and outdoor temperatures. Not for Mitsubishi Electric units: use MELCloud. Enter the IP address of each adapter (give each a fixed address in your router), save, then add the air conditioners from the Discovery tab. Gladys controls them only if you allow the commands below; it then registers on each adapter (one of its four slots). The local API has no password: keep the adapters on a trusted network. Never tested with a real device. Not affiliated with Mitsubishi Heavy Industries.
IP addresses of the WF-RAC adaptersstringJaOne per air conditioner, separated by commas (8 at most). IPv4 addresses or host names; port 51443 unless you add one.
Allow the commandsbooleanNeinOff by default. On: Gladys registers on each adapter (once, one of its four slots) and may switch the air conditioners on and off and change their mode, setpoint, fan and vane. Off: read only, nothing registered, every command refused.
Refresh interval (s)numberNeinHow often each adapter is read, in seconds.
Language of the feature namesselectNeinUsed for the names of the devices and features added from now on, for the options and for the command errors.
So installierst du Mitsubishi Heavy WF-RAC in Gladys​
  1. Öffne in Gladys Integrationen: Mitsubishi Heavy WF-RAC erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-mitsubishi-wfrac:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-mitsubishi-wfrac.
Mitsubishi Heavy WF-RAC benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Mitsubishi Heavy WF-RAC ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
