Météo Suisse / MeteoSwiss Smart-Home-Integration, kostenlos und Open Source
Météo Suisse / MeteoSwiss-Integration für Gladys Assistant
Swiss forecasts and official MeteoSwiss weather warnings.
Requires Gladys Assistant 5.2.0 or later.
Use the native Gladys Weather widget for the eight-day forecast. Add the temperature, precipitation and wind widgets for hourly charts.
In each widget's settings:
  • Location: a Swiss town or postcode, for example Genève, 1201 or 1201 Genève. Accents are optional. For cities with several postcodes, use a postcode to choose the area.
  • House: used when Location is empty. Leave both empty for the first located house, or enter the house name/selector to choose another one.
Add multiple copies of a widget to compare locations. A custom location works even without a located house. The native Gladys weather widget continues to use its selected house.
The extra Forecast · 8 days widget has been removed. If you added it, remove it from your dashboard and use the native Weather widget instead. The three chart widgets retain their settings.
First loading can take a few minutes. Up to 20 locations are tracked per integration process. An unknown or ambiguous location displays guidance instead of silently falling back to your house.
The heading shows only the location. The source and forecast time appear below the location in a small, muted subtitle. The website link is available in the integration configuration.
Scene triggers​
Add a scene trigger from Integrations → Météo Suisse / MeteoSwiss:
TriggerDefault thresholdExample use
Precipitation expectedAt least 0.2 mm in one hourSuspend irrigation
Frost riskTemperature at or below 0 °CNotify about plants
High temperature expectedTemperature at or above 30 °CClose shutters
Strong gusts expectedGusts at or above 50 km/hRetract awnings
Select a House, or leave the filter empty for events from all located houses. Each house needs coordinates in Gladys and must be covered by Swiss forecasts. Custom locations used only in widgets do not trigger scenes.
In each scene trigger, choose the threshold and the Forecast window: 1, 3, 6, 12 or 24 hours (default: 6). Each scene has its own settings; there are no thresholds to set in the integration configuration. For example, one scene can retract awnings at 40 km/h within 3 hours, while another sends a notification at 80 km/h within 12 hours.
Thresholds are selected from lists:
  • Precipitation: 0.2, 1, 2, 5 or 10 mm in one hour.
  • Frost: −5, −2, 0, 2 or 5 °C, to anticipate risk for sensitive plants.
  • Heat: 25, 28, 30, 32 or 35 °C.
  • Gusts: 30, 40, 50, 60, 80 or 100 km/h.
Arbitrary numeric input is not offered. Units remain °C, mm and km/h even when widgets use US units. Precipitation includes rain and snow; its threshold applies to one hour, not the total over the window.
Forecasts are checked at loading and every 15 minutes, even without widgets. The window includes the current hour: MeteoSwiss timestamps mark the end of each hourly interval. An event fires when any hour reaches the threshold, including the first load if a risk already exists. Another event requires a complete forecast window without that risk first. Missing data and forecasts older than six hours neither fire events nor rearm triggers.
State is stored in /data/scene-state.json to prevent repeats after reconnecting or restarting. Without a writable volume, this protection is kept only in memory. Each house/threshold/window combination is monitored independently. A scene created or edited during an already reported risk for its combination waits for the next occurrence. Changing a house's coordinates restarts its monitoring. For installations with many houses, events are spread over several minutes to respect Gladys's rate limit. Failed sends are retried on a later check; if Gladys received an event but its response was lost, a duplicate remains possible.
Following actions can use {{triggerEvent.data.house_name}}, {{triggerEvent.data.location}}, {{triggerEvent.data.value}}, {{triggerEvent.data.unit}}, {{triggerEvent.data.threshold}} and {{triggerEvent.data.horizon_hours}}. {{triggerEvent.data.forecast_at}} is the UTC end of the first hour reaching the threshold; {{triggerEvent.data.house}} is the house selector.
Official warnings​
Add Integrations → MeteoSwiss → Official MeteoSwiss warning to a scene. Select:
  • House: one house, or leave empty for all located houses.
  • Phenomenon: wind, thunderstorms, rain, snow, slippery roads, heat wave or frost. Leave empty for all seven.
  • Minimum danger level: 2 (moderate), 3 (considerable), 4 (high) or 5 (very high). A threshold of 3 also accepts levels 4 and 5.
For example, House = Home, Phenomenon = Thunderstorms, Minimum = 3 can send a notification as soon as a confirmed thunderstorm warning arrives. A separate Wind, Minimum = 2 scene can retract awnings. The official degree is a danger category, not a wind-speed threshold; the forecast triggers above remain available for numeric thresholds.
The official hazard-map feed is checked immediately at startup, then every 60 seconds, even without widgets and independently of forecast downloads. The upstream index also has a 60-second cache: allow roughly one to two minutes after web publication under normal conditions, plus network/delivery time. This is polling, not the MeteoSwiss app's push channel. Longer upstream cache directives, server-requested retry delays and outages take precedence; errors retry after 1, 2, 4, then 5 minutes. No integration can deliver a warning before MeteoSwiss publishes it.
An event fires on receipt of a new confirmed warning, even if its start is in the future, and again if its degree exceeds the highest already reported for that warning. Decreases, wording changes and extensions of the end time do not repeat it. Expired warnings, preliminary outlooks, lake/airfield warnings and other agencies' natural hazards (floods, avalanches, forest fires, drought) are excluded. Houses are matched locally against the simplified boundaries used by the official map, not against the nearest forecast town. Near a boundary, consult the official map; this is regional information, not a measurement at the house. House changes are checked every minute.
Variables: {{triggerEvent.data.house_name}}, {{triggerEvent.data.phenomenon}} (stable code such as thunderstorm), {{triggerEvent.data.level}}, {{triggerEvent.data.starts_at}}, {{triggerEvent.data.ends_at}} (UTC), and {{triggerEvent.data.source_url}} for the official map. For example: “MeteoSwiss warning: {{triggerEvent.data.phenomenon}}, level {{triggerEvent.data.level}} for {{triggerEvent.data.house_name}}.”
Warning state is persisted separately in /data/warning-scene-state.json. Reconnecting or restarting does not replay acknowledged warnings when this volume is writable. Creating a scene during an already reported warning also does not replay it. Failed sends retry; a lost acknowledgement can still cause a duplicate. A confirmed cancellation rearms the warning. Unavailable data does not clear this state. After three minutes without a successful feed check, the integration stops publishing from the old feed. Large installations are limited to 50 warning-event attempts per minute; pending work is reevaluated using current data.
Official warnings are also included in native Gladys weather responses, with the original French/English description and source link. The numeric degrees 2–5 map to Gladys severities minor, moderate, severe, extreme; slippery roads have no equivalent Gladys type. The direct integration trigger above is the fastest path and works while forecasts are still loading. Native weather refreshes share Gladys's one-per-minute limit and require an available forecast. Unavailable warning data is omitted, never reported as an empty list. For descriptions beyond Gladys's size limit, the source link replaces the text.
Source: Météo Suisse (MeteoSwiss). This independent community integration is not an official service and has no affiliation with or endorsement from MeteoSwiss. Forecasts and regional warnings complement a local sensor for equipment protection. Radar is not provided.
Diese Einstellungen fragt Météo Suisse / MeteoSwiss in seinem Konfigurationsbildschirm in Gladys ab.
MeteoSwisssectionNeinNo API key needed. Widgets use your house by default; choose any Swiss town in their settings. First load may take a few minutes. Independent, unofficial integration. Source: MeteoSwiss.
So installierst du Météo Suisse / MeteoSwiss in Gladys​
  1. Öffne in Gladys Integrationen: Météo Suisse / MeteoSwiss erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/valentinhttr/gladys-meteoswiss:1.4.0) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/valentinhttr/gladys-meteoswiss.
Météo Suisse / MeteoSwiss benötigt Gladys >=5.2.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Météo Suisse / MeteoSwiss ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von valentinhttr veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
