MELCloud Home Smart-Home-Integration, kostenlos und Open Source
Control your Mitsubishi Electric air conditioners through the MELCloud Home cloud.
Requirements
- A MELCloud Home account (
melcloudhome.com) — the new Mitsubishi Electric platform. If your account was created on the legacy MELCloud (app.melcloud.com), it will not work here: the two platforms are separate. - Your air conditioners already added to your MELCloud Home account (via the MELCloud Home mobile app).
- Enter the email and password of your MELCloud Home account. They are stored encrypted by Gladys and used only to authenticate against MELCloud Home.
- Save. The connection status is shown right on this screen.
The state of your units is refreshed every minute; there is nothing else to configure.
Adding your devices
Your units are published as soon as the integration connects, so they are already listed in the Discovery screen — run a scan to refresh the list.
- Air-to-air units (air conditioners) expose Power, Mode (heat / cool / dry / fan / auto), Target temperature and a read-only Room temperature, plus a Fan speed (auto, or only the speeds the unit actually has). Units fitted with vanes also get Vertical swing and Horizontal swing. Gladys names the "automatic" vane position "off"; it is the automatic position of your unit.
- Air-to-water units (Ecodan heat pumps) expose Power, a Zone 1 temperature setpoint and read-only Zone 1 room temperature, an Outdoor temperature sensor, and — when a hot water tank is present — Hot water temperature (setpoint), a read-only Hot water tank temperature and a Forced hot water switch.
Create the ones you want to control.
Notes
- Air-to-air (air conditioners) and air-to-water (Ecodan heat pumps) units are supported. ERV ventilation units are ignored.
- Zone operation mode (heating curve, flow vs room thermostat) is not controllable yet on air-to-water units.
- The connection status is shown on this screen; if it reports a login failure, re-check your email and password.
Diese Einstellungen fragt MELCloud Home in seinem Konfigurationsbildschirm in Gladys ab.
| MELCloud Home account | section | Nein | MELCloud Home (melcloudhome.com) is the new Mitsubishi Electric platform, separate from the legacy MELCloud. Sign in with the same email and password you use in the MELCloud Home app. |
string | Ja | The email address of your MELCloud Home account. | |
| Password | secret | Ja | The password of your MELCloud Home account (stored encrypted). |
So installierst du MELCloud Home in Gladys
- Öffne in Gladys Integrationen: MELCloud Home erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/callemand/gladys-melcloud-home:1.4.0) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/callemand/gladys-melcloud-home.
MELCloud Home benötigt Gladys >=4.86.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
MELCloud Home ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von callemand veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
