Lubluelu SL68 (Tuya) Smart-Home-Integration, kostenlos und Open Source
Control the Lubluelu SL68 and other Tuya/Smart Life robot vacuums over the LAN.
Control the Lubluelu SL68 robot vacuum — and other Tuya/Smart Life-based sweep robots — from Gladys, directly over your local network. No custom hub, no keeping the phone app open.
Overview
Day-to-day control (start/pause, mode, water level, suction, return to dock) goes straight to the vacuum over the LAN, encrypted the same way the Smart Life/Tuya Smart app talks to it — no cloud round-trip once everything is set up. Bootstrapping still needs to reach your Tuya account once, for two things only:
- fetching the device's
local_key, the encryption key local control requires (it is never broadcast on the LAN, only ever available behind your Tuya account); - reading which features your specific vacuum actually has (start/pause, mode, water level, suction, battery...) — read from Tuya's own catalog for your device, not guessed.
Two ways to do that — pick whichever suits you, or set up both:
- Smart Life account (recommended) — no developer account, no Access ID/Secret to copy: scan a QR code with the app you already use for the vacuum, and every device on the account is discovered automatically, exactly like adding a device in the official app.
- Tuya Cloud account (advanced) — a free Tuya IoT Platform project, for people who already have one or want the explicit per-device control it gives.
The local_key rotates whenever the vacuum re-links to the cloud, so this integration
re-checks it periodically in the background (either method) — you never have to redo the setup
for that.
These features show up per vacuum, automatically adapted to what your specific device reports (not every vacuum has every one of these). Their names are in French or English, as set by the Language of device names field (Gladys keeps a name as it was when the device was added):
- State — what the robot is doing: cleaning, paused, returning to the dock, charging, on the dock, stopped, error. Gladys shows it as a badge, and it can start a scene ("when the vacuum is back on its dock").
- Power / Pause — start, stop or pause the current cleaning.
- Mode — a dropdown (Smart, Along walls, Spot, Selected rooms, Mopping, Return to dock...).
- Return to dock — a one-click button.
- Water level — mopping water flow, when your vacuum has a mop function.
- Suction power — when your vacuum reports a suction/power level.
- Battery — read-only, 0-100%.
- Cleaned area / Cleaning time — of the cleaning under way or last done, and their totals.
- Fault code — read-only, 0 normally.
- Find robot — makes the vacuum chirp, when supported.
- Roll brush / Side brush / Filter / Mop pad — remaining life, and a Reset button for each after you replace the part.
- Do not disturb — when your vacuum has a quiet-hours setting.
- Zone - … — one button per cleaning zone (see "Cleaning zones" below).
Requires Gladys 5.1 or later.
Dashboard widgets
Add them from the dashboard editor (Add a widget, then this integration). Each one shows the vacuum picked in its settings, or the first one. They complement the core's Devices box, which stays the place for every setting (dropdowns, switches):
- Robot vacuum — the robot at a glance: battery, state, program, suction, water, the area and time of the cleaning under way, a fault in red, local or cloud link; and the everyday keys of its remote: Start (or Pause / Resume, following the state), Back to dock, Locate, Stop.
- Quick clean — up to four one-tap cleanings, for a wall tablet. Each button is a program (smart, edges, spot, mop) or a zone name, typed in the widget settings. Left empty, it offers the vacuum's programs then its zones. The program under way is ticked.
- Vacuum remote — manual driving: forward, turn left, turn right, stop, with the state and battery. Only on vacuums that accept direction control; keep the robot in sight.
- Vacuum maintenance — the remaining life of each part as gauges, the most worn first, and a reset key (asking for confirmation) for each worn part once you have replaced it.
Scenes
Triggers (When… in a scene):
- Vacuum: cleaning finished — the robot ended a cleaning and went back to its dock. Gives the cleaned area, the time and the battery to the next actions (for a message such as "Cleaning done: {{area_m2}} m² in {{duration_min}} min").
- Vacuum: error — the robot reported a fault (stuck, wheel, brush, dust bin...), with its description.
- Vacuum: part worn out — a part's remaining life dropped below 10%.
The robot's State is also a regular device state, usable as a trigger.
Actions (Then…):
- Vacuum: start cleaning — program, suction and water level applied together, then start: one card instead of three. Unchanged keeps the robot's current setting.
- Vacuum: clean a zone — clean a zone by its name, as on the vacuum's zone buttons
("Zone - Kitchen" →
Kitchen). Case and accents are ignored and a unique start is enough (bedfor "Bedrooms"); when several zones start the same way, the scene log lists them. Gladys cannot show the zones in a drop-down here yet; the built-in Control devices action may offer the vacuum's "Zone - …" buttons in a list instead.
Cleaning zones (LiDAR robots)
On robots that clean room by room (LiDAR robots with rooms in the Smart Life app), Gladys can send the robot to clean one room, several rooms, or a zone drawn in the app:
- The easy way — memorize it from the app. Start the room or zone clean once from the Smart Life app, while the integration is running. Then, in the integration's Configuration screen, run Memorize the last zone: pick the vacuum, give it a name ("Kitchen"). Gladys can now replay it any time.
- Or type the rooms by number, in Rooms by id (advanced):
Kitchen=2, Living room=0+1, Bedrooms=3+4x2(+for several rooms,x2for two passes). The room numbers are the robot's own: the integration logs them each time a room clean is started from the app.
Then open the Discovery tab and click Update on the vacuum: each zone gets its Zone - … button, usable from the dashboard, the Quick clean widget and the Vacuum: clean a zone scene action. Forget a memorized zone removes one. Re-mapping your home in the app can renumber the rooms: memorize the zones again after a new map.
Prerequisites
- The vacuum already set up and working in the Smart Life or Tuya Smart app.
- "Local Network Discovery" (or similar) enabled for the device in the Smart Life/Tuya Smart app (usually on by default) — some models only broadcast their LAN presence when this is on.
Configuration — Smart Life account (recommended)
This integration's Configuration screen follows these steps top to bottom, numbered:
- 1. Smart Life account: open the app on your phone, go to Me > Settings > Account and Security > User Code, copy it, then paste it into the Smart Life user code field.
- 2. Save: click Save before continuing — the next step needs this code to already be saved, or it fails with an error.
- 3. Connect and scan the QR code: click this button, a QR code opens. In the Smart Life/Tuya Smart app, tap + > Scan, point at the QR code, and tap Confirm login. The app may say the login is for "Home Assistant" — that's expected, this integration uses the same official Tuya mechanism Home Assistant's own integration does; only confirm if you just started this login yourself.
- Open the Discovery tab and run a scan — every device on the account appears automatically, with the features each one actually supports. Add the ones you want.
That's it — pairing a new vacuum later is just: pair it in the Smart Life app, then Discovery > Scan in Gladys. Nothing to configure per device.
Configuration — Tuya Cloud account (advanced)
- Go to iot.tuya.com, create a Cloud project (the free "Smart Home" template is enough).
- In the project's Devices tab, choose Link Tuya App Account and scan the QR code with the Smart Life/Tuya Smart app you use for the vacuum. Its devices then appear under All Devices.
- Copy the project's Access ID/Client ID and Access Secret/Client Secret from the project's Overview tab into this integration's Configuration screen, along with the Region your project was created in (visible in the project URL: eu/us/cn/in).
- Copy the vacuum's Device ID from the All Devices list into the Device ID(s) field (comma-separated if you have several).
- Save, open the Discovery tab and run a scan, then add the device(s).
Both methods can run at once; a device id configured under the Tuya Cloud account takes priority over the same device found via the Smart Life account.
A Test connection action is available from the Configuration screen for any added vacuum: it reports whether the local session is up, and the vacuum's last known state (or its state read via the cloud if the local session is currently down).
If the vacuum's LAN IP isn't found automatically
Discovery relies on the vacuum announcing itself on the LAN (the same broadcast the phone app
uses to find it) — the Smart Life account method also reports the IP Tuya's servers have on file
for the device as a second source. If neither finds it (blocked broadcast between VLANs, some
mesh Wi-Fi setups...), fill in Manual LAN IP(s) (advanced): device_id=ip, e.g.
eb1234567890abcdef01=192.168.1.42. A fixed IP or a DHCP reservation for the vacuum is
recommended in that case.
Only one connection at a time
Like most Tuya local-control tools, only one client can hold the vacuum's local TCP session at once. Keeping the Smart Life/Tuya Smart app open on the vacuum's device screen at the same time this integration is connected can make both flaky — this is a limitation of the vacuum's own firmware, not something this integration can work around.
"No room or zone clean seen since the integration started" when memorizing a zone: start the room/zone clean from the Smart Life app after the integration started, wait a few seconds, then run the action again. If it still fails, your robot doesn't report its room selection: type the rooms by number instead.
A zone button does nothing: the room numbers may have changed after a new map in the app — memorize the zone again.
"Enter your Smart Life user code first" even though it's filled in: the form wasn't saved before clicking the connect button — those are two separate actions. Click Save, wait for the confirmation, then click 3. Connect and scan the QR code. If the error persists, check the integration logs (
docker logs): starting with 0.2.2, a failed attempt shows the exact detail there. -
The QR code isn't confirmed / times out: it expires in 1-2 minutes — reopen it (click Connect again) and scan promptly. If the app doesn't recognize it as valid, try switching QR app (advanced) between Smart Life and Tuya Smart in the Configuration screen and reconnecting.
Discovered but stuck "not connected": check the manual LAN IP fallback above, and make sure nothing else (the phone app, another automation tool) is holding the local session.
"Local session unreachable, falling back to the Tuya cloud API" badge: the integration keeps working through cloud commands/status while it retries the local connection in the background — commands still work, just with more latency and a cloud round-trip until the LAN session recovers.
A feature you expect (e.g. Water level) is missing: your vacuum's Tuya catalog entry may not report that code, or reports it under a name this integration doesn't yet recognize. Check the integration logs (
LOG_LEVEL=debug) for the raw schema fetched from Tuya. -
The integration logs everything it does: check the integration logs from the Gladys UI (or
docker logson the host) withLOG_LEVEL=debugfor the full detail.
Diese Einstellungen fragt Lubluelu SL68 (Tuya) in seinem Konfigurationsbildschirm in Gladys ab.
| Language of device names | select | Nein | Names of the features and choices created in Gladys, and of the scene event messages. Widgets always follow your own language. |
| 1. Smart Life account (simple, recommended) | section | Nein | No Tuya developer account needed. Enter your Smart Life user code below — Me > Settings > Account and Security > User Code in the app. |
| Smart Life user code | string | Nein | |
| 2. Save | section | Nein | Click Save now, before continuing — step 3 below needs the user code you just entered to already be saved, or it will fail. |
| 3. Connect and scan the QR code | account_link | Nein | Opens a QR code — scan it with the Smart Life/Tuya Smart app and tap "Confirm login". Every device on your account is then discovered automatically. |
| QR app (advanced) | select | Nein | Change only if scanning or confirmation does not work for your account. |
| Alternative: Tuya Cloud account (advanced, optional) | section | Nein | This vacuum is controlled directly over your LAN once configured — no cloud round-trip for day-to-day commands. But the device's local_key (and its rotation over time) only ever lives behind the Tuya Cloud account your Smart Life/Tuya Smart app uses, so a free Tuya IoT Platform project is required once: create a Cloud project, link your Smart Life/Tuya Smart app account to it (Devices tab -> Link Tuya App Account, scan the QR code with the app), then copy the project's Access ID/Client ID and Access Secret/Client Secret below, and the vacuum's Device ID from the All Devices list. |
| Access ID / Client ID | secret | Nein | |
| Access Secret / Client Secret | secret | Nein | |
| Tuya data center | select | Nein | The data center your Cloud project was created in (visible in its URL on the Tuya IoT Platform: eu/us/cn/in). |
| Device ID(s) | string | Nein | The vacuum's Device ID, from the Tuya IoT Platform's All Devices list (Devices tab). Several vacuums: separate their ids with commas. Not needed with the Smart Life account method above, which discovers every device automatically. |
| Manual LAN IP(s) (advanced) | string | Nein | Only needed if the automatic LAN broadcast scan does not find a device's IP (blocked VLAN, "Local Network Discovery" disabled in the app...). Comma-separated device_id=ip pairs, e.g. "eb1234...=192.168.1.42". |
| Tuya Cloud refresh interval (min) | number | Nein | How often the local_key and IP are re-checked against the Tuya Cloud API. The local_key rotates whenever the device re-links to the cloud, so this must run occasionally even though day-to-day control stays local. |
| Local protocol version (advanced) | select | Nein | Fallback used only when the LAN broadcast scan hasn't identified the device's own version yet. Most devices from 2020 onwards use 3.3 or 3.4, recent ones 3.5. |
| Cleaning zones (LiDAR robots) | section | Nein | Clean one room, several rooms or a zone drawn in the app, from a button, a widget or a scene. Easiest: start the clean from the Smart Life app once, then run the "Memorize the last zone" action below with a name. Or type the rooms by their id (the integration logs the ids each time a room clean is started from the app). Then click "Update" on the vacuum in the Discovery tab. |
| Rooms by id (advanced) | string | Nein | Comma-separated name=ids, several rooms joined with +, x2 for two passes. Example: "Kitchen=2, Living room=0+1, Bedrooms=3+4x2". |
So installierst du Lubluelu SL68 (Tuya) in Gladys
- Öffne in Gladys Integrationen: Lubluelu SL68 (Tuya) erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/lm1lc3n7/gladys-lubluelu-vaccum:0.3.3) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-lubluelu-vaccum.
Lubluelu SL68 (Tuya) benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Lubluelu SL68 (Tuya) ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
