JVC Projector Smart-Home-Integration, kostenlos und Open Source
JVC Projector-Integration für Gladys Assistant
JVC D-ILA projectors on the local network: power on, standby, input, picture mode, lamp hours.
Control your JVC D-ILA projectors (DLA-NZ, NX, N, X, RS and Z series, 2012 models on) from Gladys, on your local network, without any cloud: power on, standby, input, picture mode, remote keys, signal and lamp / laser hours.
Important. This integration has never been tested with a real projector: it was written from the pyjvcprojector library (the one of Home Assistant) and tested against a fake projector only. Your feedback is welcome. Unofficial integration, not affiliated with JVCKENWOOD.
  1. Connect the projector to your network (LAN port) and give it a fixed IP address in your router (reserved DHCP lease), or set one in its Network menu.
  2. To control it in standby, keep its network on in standby: set ECO mode to Off (otherwise it leaves the network in standby, and only the remote can turn it on).
  3. Recent models (2024 on, and some after a firmware update) require a network password set in the projector's Network menu: type it in the configuration. Older models have none: leave the field empty.
  4. In Gladys, install the JVC Projector integration, open its configuration and type the IP addresses, separated by commas (for example 192.168.1.50; port 20554 by default, another one as 192.168.1.50:20555).
  5. The projectors appear in the Discovery tab: create them.
The projector must be on, or in standby with its network kept on, the first time: the integration reads its model and its MAC address, which identifies it from then on (its address may change: type the new one).
FeatureGladys typeNote
Powerbinary state (read only)1 on or warming up, 0 standby, cooling down, error or not reachable
Power statustext (read only)On, Warming up, Cooling down, Standby, Error, Not reachable
Power onbuttonsent from standby only
Standbybuttonsent when on; while warming up, sent as soon as the projector is on
InputlistHDMI 1, HDMI 2
Picture modelistthe modes of your model (Film, Cinema, Natural, HDR10, User 1…)
Remote keylistMenu, arrows, OK, Back, Info, Lens control, Mode 1 to 10…
Signalbinary state (read only)1 when the input has a signal
Lamp / laser timeduration in hoursread while the projector is on
On purpose, no switch: an "everything off" or "everything on" from a voice assistant or a scene never turns your projector on or off. Use the two buttons in your scenes.
Input, picture mode and signal are read while the projector is on (the picture mode with a signal only, as Home Assistant does). The picture mode list follows the model the projector reports; a model the integration does not know offers no picture mode.
Commands​
The power state is read from the projector just before each command, then its MAC address when it answered it before in that state (another projector at the address: nothing is sent, and the address is forgotten). Every background read checks the MAC too. Only a valid MAC address of another projector counts: a projector that does not answer its MAC in standby, or answers zeros, keeps its address and can still be powered on.
  • Power on is only sent in standby. Already on or warming up: nothing to do. While cooling down, the projector refuses it: the command is refused, nothing sent; try again once it is in standby.
  • Standby is only sent when on. Already in standby or cooling down: nothing to do. While warming up, the projector ignores it: Gladys gets the answer "warming up: standby will be sent once it is on, nothing sent yet", and the integration sends it as soon as the projector is on (checked every 5 seconds, within 3 minutes, a failed read included); pressing Power on meanwhile cancels it. Standby is never refused because the state could not be read: it is then sent anyway. It goes before the other commands waiting, and never waits behind a background read or the slow confirmation of an input or picture mode change (that connection is closed; the change stays "sent, without confirmation").
  • Input, picture mode and remote key are only sent when the projector is on.
Every command is answered within 4 seconds (Gladys waits 5 seconds). A command that left without the projector confirming it in time is reported "sent, without confirmation" (an input change can take up to 10 seconds on the projector); one that could not leave is reported "nothing sent". The state is read again 3 seconds after each command.
Network password​
The password is kept by Gladys in its database, never shown again, and sent only to the projectors, at the start of each connection (padded as the older models expect it, then in the SHA-256 form of the recent models when the first one is refused, as pyjvcprojector does). The integration never writes it to its data folder, nor to its logs, statuses or error messages.
A refused password stops the tries to that projector: the integration status says so, and the password is tried again only when you save the configuration, or 30 minutes later (never in a loop). A projector that closes the connection or stops answering after refusing a password counts as a refusal too. Fix it in the projector's Network menu or in the configuration, then save.
Configuration button​
  • Check the projectors: reads each projector now (power, lamp hours) and shows the refresh interval.
Refresh, status and limits​
  • The state of each projector is read every 15 seconds by default (10 to 300), in one short connection (the projector takes one client at a time: close the JVC app or another controller if it says "busy").
  • A projector that does not answer shows power 0 and "Not reachable", and is named in the integration status; it is asked again at every refresh, never faster.
  • If another projector answers at the address of a created one (address changed), its address is forgotten and it is never commanded there: type its new address.
Data and privacy​
The integration keeps in /data/jvc-projector.json the known projectors (MAC address, address, port, model, picture modes) and the addresses whose password was refused, with the time of the next try. Nothing leaves your local network.
Known limits​
  • HDMI 1 and HDMI 2 only (the inputs pyjvcprojector maps).
  • No lens memory, laser power, installation mode, anamorphic or HDR settings yet.
  • One password for all the projectors.
  • Never tested with a real projector: real answers may differ.
Diese Einstellungen fragt JVC Projector in seinem Konfigurationsbildschirm in Gladys ab.
Your JVC projectors, on your local networksectionNeinPower on, standby, input, picture mode, remote keys, signal and lamp / laser hours of each JVC D-ILA projector (DLA-NZ, NX, N, X, RS, Z series), through the network protocol published by JVC (TCP port 20554), without any cloud. Give each projector a fixed IP address in your router and type it below; the projectors then appear in the Discovery tab. To control a projector in standby, keep its network on in standby (ECO mode off). Power on and standby are buttons, never a switch: an "everything off" never turns a projector on or off. Never tested with a real projector. Unofficial integration, not affiliated with JVCKENWOOD.
IP addresses of the projectorsstringNeinSeparated by commas, for example 192.168.1.50, 192.168.1.51. Port 20554 by default (another one: 192.168.1.50:20555).
Network password of the projectors (optional)secretNeinOnly if a network password is set on the projector (Network menu; required by the recent models): the same for every projector. Kept by Gladys in its database, never shown again, sent only to the projectors, at the start of each connection. A refused password stops the tries until the configuration is saved again (or 30 minutes).
Refresh interval (s)numberNeinHow often the state of each projector is read, in seconds (10 to 300).
So installierst du JVC Projector in Gladys​
  1. Öffne in Gladys Integrationen: JVC Projector erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-jvc-projector:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-jvc-projector.
JVC Projector benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
JVC Projector ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
