JUNG HOME Smart-Home-Integration, kostenlos und Open Source
JUNG HOME lights, covers, sockets and room thermostats, through the gateway. Unofficial.
This integration connects your JUNG HOME installation to Gladys through the local API of the JUNG HOME gateway (Bluetooth Mesh to IP). Everything stays on your local network. Unofficial, not affiliated with JUNG (Albrecht JUNG GmbH & Co. KG).
Never tested with a real device yet: the integration was written from the
protocol documentation of the junghome reference library (MIT) and tested
against a simulated gateway. Your feedback is welcome.
In the Discovery tab:
- Lights (on/off) and dimmers (brightness);
- Roller shutters and blinds: open, close, stop, position (the slats are not driven yet);
- Sockets: their state, a "Turn off" button, and their power when the socket measures it; a socket declared safe becomes a switch;
- Room thermostats: ambient temperature, setpoint, a "Frost protection" button;
- Rocker buttons: a press up or down reaches your Gladys scenes;
- Sensors: temperature, illuminance, power;
- JUNG HOME scenes: a "Recall" button each.
The device ids are tied to the serial number of the gateway and to the id of
each function (function:sn<serial>_<function>): they do not change with an
update, but a function paired again in the JUNG HOME app becomes a new device.
On a firmware without the serial number, the MAC address replaces it.
- Type the IP address of the gateway (shown in the JUNG HOME app or in
your router) and save. Names in
.localdo not resolve in the container. - Click Request access. The integration first reads the certificate of the gateway and pins it (its SHA-256 fingerprint is shown), then sends one request as "Gladys".
- In the JUNG HOME app: Settings, Gateway, Access permissions, Open requests, accept "Gladys" within 3 minutes. The token is saved by itself and the connection starts.
- Add the devices you want from the Discovery tab.
The token is kept by Gladys in its database, never shown again, sent only to the gateway at the address typed, and only on a connection whose certificate is the pinned one.
Certificate of the gateway
The gateway has a self-signed certificate. The integration accepts only the pinned one: learnt on your first click of "Request access" or "Test the connection", or typed in the Certificate fingerprint field. If another certificate shows up (gateway replaced, card reinstalled, or another device at this address), nothing is sent, not even a stop, and the status shows the fingerprint seen. To trust it: click Trust the new certificate twice (the second click within 2 minutes), or type this fingerprint in the configuration.
What always leaves, what is off by default
Always leave: turning off a light or a socket, stopping a cover, closing a cover, the frost protection of a thermostat. No option, no 429 pause, no read or command in flight, no serial number not read again yet holds them back. They cancel the commands of the same target still waiting: nothing asked before a stop leaves after it.
A stop does not leave only in these cases; it is then kept (the status says it) and sent as soon as it can be:
- address or token missing or invalid, or token refused by the gateway: it leaves first as soon as a new token is saved or "Test the connection" succeeds;
- no pinned certificate, or certificate changed: it leaves once the certificate is pinned or recognized again;
- gateway unreachable, or the route refused (401/403) while the function list still accepts the token: it is sent again every 5 seconds, with no time limit (only a refusal of the function list is a refused token);
- before the configuration is first read from Gladys (container start): it is refused, nothing sent (the token is not known yet).
A switch-off or a frost protection stays kept, also in /data (a restart of
the container sends it first, as soon as the configuration is read), until a
read started after the answer of the gateway shows it applied. If the read
shows otherwise, it is sent again; only the sends the gateway answered count,
4 at most (after a restart of the container, it leaves once more at least).
After 4 refusals of the gateway (device
locked, wind alarm) or 4 sends not applied, it stays kept and shown, with no
new send, until a read shows it applied or a newer command. A newer command of the same target, taken by the gateway, replaces
it. A cover move (close, stop) is done once the gateway took it, and is never
replayed after a restart. A close that did not reach the gateway is first
tried again twice within about 250 ms of your click (still your click: the
cover opened by hand within those 250 ms may be closed over); after that, it
is sent again only after a read of the cover, once per read: closed or
closing, it is done; read more open than when you clicked twice in a row, it
was opened by hand meanwhile and the close is dropped. An opening by hand
between that read and the send (a few milliseconds) cannot be seen.
Off by default:
- Sockets: a socket may feed anything, and a "turn everything on" of a
voice assistant or a scene reaches every switch. A socket is therefore only
a state and a "Turn off" button until you declare it safe (field Sockets
declared safe, with the
JUNG_FUNCTIONid shown in the Discovery); it then becomes a switch after a new Scan. - Heating setpoints: read only until you allow them; then between 5 and 30 °C (the bounds of the thermostat), in steps of 0.5 °C rounded down.
- JUNG HOME scenes: a scene may turn on any socket; their button does nothing until you allow them.
The option is read again right before sending: turned off while a command waits, the command is refused.
What a refused command says
A command (other than a stop) leaves within 3.5 seconds or not at all: "nothing sent" says it never left. "Refused by the gateway" gives its reason (device locked, wind alarm...). "Sent, without confirmation" says it left with no answer; "not applied yet" that a read back does not show it yet. In these last two cases, the device is read again after 5 and 20 seconds and its badge says so meanwhile.
Reads and live updates
With live updates (the default), the gateway sends each change over a WebSocket; the full list is read again every 5 minutes. Without them, or when the connection is lost, the list is read at the chosen interval (60 s by default). Never faster: neither the Scan button (which publishes the Discovery again without reading), nor the "Test the connection" button (which then says when it can test again), nor a restart of the container reads before the interval after the last read; a new address or a new token saved reads at once. A read made by the Test button is the read of the integration: its list is used at once (connected right after a successful test) and the next read comes at the interval after it. While the token is refused (no read runs then) or another gateway answers (the reads go on, its functions are not offered), the Test button tries at once, once per 10 seconds, each try reading the function list. During a pause asked by the gateway (429), neither the Test button nor "Request access" sends a request; only the stops leave.
A press of a rocker is seen live only. The 2.2.0 firmware of the buttons sends each press twice, about 1 s apart: a second press of the same button within 1.2 s is ignored.
Known limits
- The slats of blinds, the colour temperature and awnings (reversed direction) are not driven yet.
- The energy counter of the sockets (only on an experimental route of the gateway) is not read.
- A long press and a double press are not told apart.
- Access by the network key password is not offered: only by approval in the JUNG HOME app.
- "The certificate of the gateway changed": see above.
- "The gateway refused the token": access was withdrawn in the app; click "Request access" again.
- "Another gateway answers at this address": the serial number read is no longer the one learnt; "Test the connection" accepts the new gateway.
- "/data is unreadable": the integration works, but learns and keeps nothing (certificate, identity, stops); type the fingerprint of the certificate in the configuration.
Diese Einstellungen fragt JUNG HOME in seinem Konfigurationsbildschirm in Gladys ab.
| Your JUNG HOME installation in Gladys | section | Nein | The functions of your JUNG HOME gateway are offered in the Discovery tab: lights and dimmers, roller shutters and blinds, sockets, room thermostats, rocker buttons, sensors, and your JUNG HOME scenes. Everything stays on your local network, through the local API of the gateway, with live updates. Save the address, click "Request access" and accept "Gladys" in the JUNG HOME app. Never tested with a real device yet. Unofficial, not affiliated with JUNG. |
| Address of the gateway | string | Ja | The local IP address of your JUNG HOME gateway, like 192.168.1.30 (shown in the JUNG HOME app or in your router). The token is sent to this address only, over its pinned certificate. |
| Token of the gateway | secret | Nein | Filled in by the "Request access" button below once you accept "Gladys" in the JUNG HOME app. Kept by Gladys in its database, never shown again, and sent only to the gateway at the address above. |
| Certificate fingerprint (optional) | string | Nein | The SHA-256 fingerprint of the gateway certificate. Empty: learnt on your first click of "Request access" or "Test the connection", then checked on every connection (the token never goes to another certificate). |
| Live updates | boolean | Nein | Listens to the WebSocket of the gateway: the states follow within a second and the rocker presses reach your scenes. Off: the states are read at the interval below and the presses are not seen. |
| Read interval without live updates (s) | number | Nein | How often the states are read when the live updates are off or lost (30 to 3600 s). With them, every 5 minutes. Never faster, even after a restart. |
| Commands | section | Nein | Turning off, stopping or closing a cover and the frost protection of a thermostat always leave, whatever the options below. A socket may feed anything (a heater, a freezer, a pump) and a "turn everything on" of a voice assistant or a scene reaches every switch: a socket only has "Turn off" until you declare it safe. Heating setpoints and JUNG HOME scenes (which may switch any socket) stay off until you allow them. |
| Sockets declared safe | string | Nein | The function ids of the sockets that may be turned on at any time (parameter JUNG_FUNCTION in the Discovery tab), separated by commas. They become switches after a new Scan. Only sockets of a lamp or of a device that may start at any time. |
| Allow heating setpoints | boolean | Nein | Off by default: the setpoints of the room thermostats are read only (the frost protection still leaves). On: Gladys may set them, between 5 and 30 °C. |
| Allow JUNG HOME scenes | boolean | Nein | Off by default: a JUNG HOME scene may turn on any socket, safe or not. On: their "Recall" button runs them, from the dashboard and the scenes of Gladys. |
| Language of the feature names | select | Nein | Used for the names of the features of the devices added from now on, and for the refusals. |
So installierst du JUNG HOME in Gladys
- Öffne in Gladys Integrationen: JUNG HOME erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/lm1lc3n7/gladys-jung-home:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-jung-home.
JUNG HOME benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
JUNG HOME ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
