inexogy (Discovergy) Smart-Home-Integration, kostenlos und Open Source
inexogy (Discovergy)-Integration für Gladys Assistant
Unofficial: inexogy (Discovergy) smart meters: power, electricity index, gas, water.
Unofficial integration, not affiliated with inexogy. It reads the smart meters of an inexogy customer account (formerly Discovergy, Germany) through the official inexogy API (api.inexogy.com), with the e-mail and the password of the inexogy web portal. Read-only: nothing is ever commanded.
Never tested with a real device nor a real inexogy account: it was built from the pydiscovergy library (used by Home Assistant) and its test answers. Feedback welcome.
One Gladys device per meter of the account:
MeterFeatures
Electricitypower (W, as inexogy gives it: negative while injecting on a two-way meter), consumption index (kWh, fed to the Gladys energy monitoring), tariff 1 and 2 registers, injection index, power and voltage of each phase
Gasgas index (m³), a plain sensor
Waterwater index (m³), a plain sensor
A feature exists only once inexogy gives its value (a counter: once above 0). Other kinds of meters (heat...) are listed in the status, not read.
  • The consumption index is the meter's own total register (energy): the Gladys core derives the consumption and its cost from it. It is never a sum of the tariffs and never holds the injection.
  • Gas and water stay out of the energy monitoring (Gladys would price them at the electricity tariff): plain volume sensors.
  • The tariff registers and the injection are plain sensors (kWh in their name): as indexes they would be counted twice, or billed.
Setup​
  1. In Gladys, open the integration and enter the e-mail and the password of your inexogy customer account (the ones of https://my.inexogy.com/). The password is kept by Gladys in its database, never shown again, and only sent to inexogy (api.inexogy.com, HTTPS) with each request (HTTP Basic, the authentication of the official API).
  2. Optionally choose the minutes between two reads (1 by default, 60 at most).
  3. Save, then open the Discover tab and create the devices you want.
How it behaves​
  • Pace: one read every interval (the last reading of each meter, and the meter list once an hour), never more often: not after a restart of the container (the time of the last read is kept in /data), a reconnection, a save of the form, the Discover tab nor the test button.
  • Refused login (HTTP 401 or 403 on the meter list): the integration stops and says so; nothing more is sent with these credentials, even after a restart. Save the right ones, or click "Test the connection" for one more try (never sooner than the interval).
  • inexogy asks to wait (HTTP 429, or 5xx on the meter list or on every meter): every read pauses, from 1 minute to 6 hours (its Retry-After is followed within those bounds), kept across restarts. A 5xx on one meter only leaves the others going.
  • Stale reading: when the last reading of an electricity meter is more than 15 minutes old on the clock of inexogy, its power and voltages are not sent (never an old value as a new one); the counters still are.
  • At most 280 values a minute are sent to Gladys (its limit is 300).
The consumption index is protected​
Gladys counts every rise of an index in full. A glitch (a register at 0, a wrong value) would become thousands of kWh. So:
  • 0 is never sent;
  • a value lower than the last one (a drop) is held, and never accepted: the index goes on by itself when the register comes back. A meter really replaced or reset: delete its device and create it again;
  • a rise faster than 100 kW on average since the last value (a jump) is held, never confirmed by time, repetition or a restart (kept in /data); while held, the last accepted value is sent again and the status says so. If that energy was really consumed, click "Accept the held index" twice: the first click lists the jumps, the second (within 5 minutes) takes exactly those values. Saving the configuration never accepts anything.
After 24 hours without any reading, up to 2,400 kWh may pass at once (the margin grows with the time since the last value).
Privacy​
/data/inexogy-state.json keeps the time of the last read, a pause, the fingerprint (salted) of refused credentials only (erased at the first success), and the reference of each consumption index. Never the password, the e-mail, a serial number nor an address: the location inexogy keeps for a meter is never read. The logs and the status hold our own words only. In Gladys itself, the serial number of a meter names its device, and its full serial number and make are parameters of the device (kept in the Gladys database).
Limits​
  • Only the first 10 meters of an account are read.
  • The scales of the values are the ones of Home Assistant (power in mW, energy in 1e-10 kWh, volume in 1e-3 m³); the water meters were never seen.
  • No history import, no load disaggregation, no statistics.
  • Not the P1 Monitor, YouLess or Tibber integrations.
Credits​
The API calls and the meaning of the values are ported from pydiscovergy (MIT, Jan-Philipp Benecke); see THIRD_PARTY_NOTICES.md.
Diese Einstellungen fragt inexogy (Discovergy) in seinem Konfigurationsbildschirm in Gladys ab.
inexogy customer accountsectionNeinUnofficial connector, not affiliated with inexogy. It reads the smart meters of your inexogy account (formerly Discovergy, Germany) through the official inexogy API, with the e-mail and password of the inexogy web portal: the power and the electricity index every minute (the index is fed to the Gladys energy monitoring), and, when the meter gives them, the tariff registers, the injection, the power and voltage of each phase, and the gas and water meters. Gas and water are plain sensors in m³: they stay out of the energy monitoring. Read-only: nothing is ever commanded. Never tested with a real device.
inexogy e-mailstringJaThe e-mail of your inexogy customer account (the one of the web portal).
inexogy passwordsecretJaKept by Gladys in its database, never shown again, only sent to inexogy (api.inexogy.com, HTTPS) with each request.
Minutes between two readsnumberNeinEach read asks inexogy for the last reading of every meter (and for the meter list once an hour). Never more often, whatever happens (a restart, the test button).
So installierst du inexogy (Discovergy) in Gladys​
  1. Öffne in Gladys Integrationen: inexogy (Discovergy) erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-inexogy:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-inexogy.
inexogy (Discovergy) benötigt Gladys >=5.2.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
inexogy (Discovergy) ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
