Hoymiles (OpenDTU) Smart-Home-Integration, kostenlos und Open Source
Unofficial connector: Hoymiles micro-inverters through OpenDTU, solar production, power limit.
Unofficial connector, not affiliated with Hoymiles nor with the OpenDTU project. It brings your Hoymiles micro-inverters into Gladys through OpenDTU, the open-source gateway (an ESP32 with an NRF24 or CMT2300A radio module) that talks to the inverters. Everything stays on your local network: no cloud, no account. Hoymiles is a trademark of Hoymiles Power Electronics Inc.
What you need
- An OpenDTU that already shows your inverters in its own web interface (HM, HMS and HMT series). AhoyDTU, the other open firmware, is not supported yet.
- Its IP address on your network. Give it a fixed address in your router (DHCP reservation) so it does not move.
- Optional: the OpenDTU admin password (the one of its web interface,
user
admin), to change the power limit and turn an inverter on or off.
| Surface | Content |
| One device per inverter | solar power (W), the power of each panel named as in OpenDTU, the energy of the day (kWh), the lifetime energy (kWh) for the energy monitoring, grid voltage and frequency, inverter temperature, efficiency, power limit, on/off |
| Scene triggers | production started (morning), production stopped (evening, with the energy of the day), inverter alarm (grid overvoltage, over temperature…) |
| Scene actions | set the power limit (watts or percent), solar production (power, energy of the day and lifetime, of one inverter or all of them) |
| Dashboard widget | Solar production: power now, today, lifetime, each panel, the limit, and whether the inverter sleeps |
Setup
- Install the integration and type the OpenDTU address (for example
192.168.1.50). ItsOpenDTU-xxxxxxname only works if your router's DNS knows it: the integration runs in a container that does not see the mDNS names of the network. - Optional: type the admin password. Without it the integration only reads. If you turned off "Allow read-only access" in OpenDTU (Settings → Security), the password is needed to read as well.
- Press Test OpenDTU: it lists your inverters and checks the password.
- Open Discovery and add your inverters. Put the Solar production widget on a dashboard.
OpenDTU is read every 15 seconds (option Refresh interval, 5 seconds at least: OpenDTU itself polls the inverters every 5 seconds).
The night is not an error
A micro-inverter is powered by its panels: without sun it switches off and OpenDTU no longer reaches it. The integration then shows a power of 0 W, keeps the energy indexes, marks the inverter "sleeping (night)" and reads OpenDTU once a minute until an inverter wakes up. The status of the integration stays green. After midnight, the energy of the day reads 0 until the inverter wakes up.
Energy monitoring
The lifetime energy feature is a production index: Gladys turns it into a 30-minute production (the "Lifetime energy (30-minute production)" feature, which Gladys fills itself) for its energy screens. The index never goes back: if OpenDTU restarts and has not read the inverter yet, the integration waits for the real value.
Power limit and on/off
The limit is temporary (non-persistent): the inverter forgets it when it restarts, at the latest the next morning. A persistent limit is never sent, because it is written to the inverter's memory, which wears out. Use the slider of the device, a scene, or the set the power limit action (in watts or in percent of the maximum power). Both commands need the admin password and an inverter that is awake: at night OpenDTU cannot reach it and would drop the command. Turning an inverter off stops its production until you turn it back on.
Scenes
- Production started: the inverter has produced for 5 minutes after a pause. The flicker of dawn fires nothing: once a day as a rule.
- Production stopped: no production for 15 minutes.
{{triggerEvent.data.energy_today}}holds the energy of the day, for an evening summary. - Inverter alarm: a new entry in the inverter's event log, with
{{triggerEvent.data.alarm}}(the message in English) and{{triggerEvent.data.code}}. The daily entries (start, "no input" at dusk) are left out.
Leave the inverter empty to react to any of them. The solar production
action gives power, energy_today, energy_total, producing and
sleeping for a message or a condition. The following actions of the scene
find them in their variable list (written {{<step>.<action>.<key>}}, for
instance {{0.0.power}} when this action is the first of the scene).
- "OpenDTU does not answer": check the address in a browser on the same network; the Gladys host must be able to reach it (same LAN or a route).
- "OpenDTU refused the access": "Allow read-only access" is off in OpenDTU and the password is missing or wrong.
- A panel is missing: the inverter was added while OpenDTU could not give its inputs; open Discovery again and press Update on the device.
- A command fails with "sleeping": try again while the inverter produces.
LOG_LEVELvariable.
Privacy
The integration talks to your OpenDTU only, on your local network. The password is sent to OpenDTU and nowhere else; it is never logged.
Diese Einstellungen fragt Hoymiles (OpenDTU) in seinem Konfigurationsbildschirm in Gladys ab.
| Hoymiles through OpenDTU | section | Nein | Unofficial connector, not affiliated with Hoymiles nor with the OpenDTU project. It reads OpenDTU, the open-source gateway (an ESP32 with an NRF24 or CMT2300A radio) that talks to Hoymiles micro-inverters, on your local network, no cloud: one device per inverter with its power, the power of each panel, the energy of the day and a lifetime index for the energy monitoring, the temperature, the power limit and an on/off switch. At night the inverters sleep: the power reads 0, that is not an error. Scene triggers when production starts or stops and on an inverter alarm, and a dashboard widget. AhoyDTU is not supported. |
| OpenDTU address | string | Ja | The IP address of OpenDTU on your network (a fixed DHCP lease helps), optionally with a port. Its "OpenDTU-xxxxxx" name only works if your DNS knows it: the integration runs in a container that does not see mDNS. |
| OpenDTU admin password | secret | Nein | The password of the OpenDTU web interface (user "admin"). Needed to change the power limit and to turn an inverter on or off, and to read when "Allow read-only access" is off in OpenDTU. Leave empty to only read. Sent to OpenDTU only, stored encrypted by Gladys. |
| Refresh interval (s) | number | Nein | How often OpenDTU is read during the day. OpenDTU itself polls the inverters every 5 s at best; at night (every inverter asleep) the integration reads it once a minute. |
So installierst du Hoymiles (OpenDTU) in Gladys
- Öffne in Gladys Integrationen: Hoymiles (OpenDTU) erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/lm1lc3n7/gladys-hoymiles:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-hoymiles.
Hoymiles (OpenDTU) benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Hoymiles (OpenDTU) ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
