GreenEye Monitor Smart-Home-Integration, kostenlos und Open Source
GreenEye Monitor-Integration für Gladys Assistant
Brultech GreenEye Monitor: energy and power per channel, pulses, temperatures, locally.
This integration shows in Gladys the values of a Brultech GreenEye Monitor (GEM), the 32-channel energy monitor made in British Columbia: energy and power of each channel, current, voltage, pulse counters (water, gas) and temperatures. Everything stays on your local network, without any cloud.
Unofficial integration, not affiliated with Brultech. Never tested with a real GEM: it follows the GEM packet format document of Brultech and the siobrultech-protocols and greeneye-monitor libraries (MIT) of Home Assistant, and is tested against their packet captures. Your feedback with a real monitor is welcome.
Read only: nothing is ever sent to the GEM. The integration never changes a setting of the monitor.
  • one device GreenEye <serial> (the monitor): voltage (V), the pulse counters that counted (raw pulse counts), the temperatures (°C) once their unit is chosen;
  • one device per channel, GreenEye <serial> channel <n>: energy index (kWh, for the energy monitoring of Gladys), power (W) and current (A); on a NET channel that produces (solar), an index of the energy produced (kWh), and a negative power while it produces.
A channel shows in the Discovery tab once it measured energy (its counter rose between two packets). The unused channels of a 48-channel packet carry fixed junk values: they never appear by themselves. To choose the channels yourself, type them in Channels to show (like 1-12, 15).
The serial number of the GEM is in every external id: a second GEM never takes the history of the first one.
Settings of the GEM​
In the web page of the GEM, in the packet sending settings ("Packet Send", TCP client mode):
  • server: the IP address of the Gladys machine on your network;
  • port: the port shown in the "How the GEM reaches Gladys" section of the configuration screen (chosen by Gladys, see below);
  • packet format: a binary format, BIN48-NET, BIN32-NET, BIN48-NET-TIME, BIN48-ABS or BIN32-ABS. Use a NET format if a channel measures a solar production: with an ABS format the GEM counts the energy of both directions together, and the index of such a channel adds the production to the consumption. On a NET channel the GEM counts the production in its "polarized" counter: the CT must face the way the GEM expects (the direction set on the GEM), otherwise consumption and production swap (the status says when a consumption index reads 0 or less). The ASCII formats and the ECM-1220/1240 monitors are not handled (the status counts the ECM packets ignored);
  • interval: any (1 to 255 s). The power is the average over the last two packets.
Temperatures: choose the unit of the GEM​
The packets carry the temperatures in the unit set on the GEM (°C or °F) without saying which one. Choose it in Temperature unit set on the GEM: °F values are converted exactly to °C ((°F − 32) × 5/9, rounded to 0.01), and the bounds (−55 to 125 °C, the range of the sensors) are checked after the conversion. Off (the default): no temperature is published. A sensor reading exactly 0 or "no sensor" (above 255) is not a value: never published.
How the GEM reaches Gladys​
The GEM opens the connection (TCP) itself; Gladys does not poll it. So the integration starts a small receiver next to it (the gem-link container), whose port Gladys publishes on the machine.
  1. Give the GEM a fixed IP address in your router.
  2. In the Configuration screen of the integration, type that address and save. Nothing listens before: the receiver starts only once a valid address is saved, and stops if you clear it.
  3. Reload the screen: the "How the GEM reaches Gladys" section shows the port Gladys chose (a free port, kept afterwards).
  4. Set the GEM as above. The status turns to "GEM … connected" at the first packet.
The Gladys core runs on the host network of the machine (network_mode: host), but integrations run in isolated containers: they cannot listen on the machine themselves. The gem-link receiver is a sub-container declared in the manifest, whose TCP port 8000 Gladys publishes on every address of the machine. It is the same mechanism as the Wolf ISM8 integration, checked in a test Gladys: a connection from the network keeps its real source address; a connection started on the Gladys machine itself arrives with the address of the Docker gateway. Hence:
  • allow this TCP port in the firewall of the machine, if it has one;
  • Check the sender (on by default) accepts only the address of the GEM; another address is refused before a byte is read and shown in the status. With Docker Desktop (Mac, Windows) or rootless Docker, Docker may replace the source address: turn the option off in that case only. Any machine of your network can then take the place of the GEM: it only has to copy its serial number (it is in every packet) to send false values, and those values go into the energy indexes (up to 100 kWh per hour per channel without being held). Even with the check on, a machine that takes the IP address of the GEM (the GEM switched off, an ARP spoof) gets through: keep the GEM on a trusted network;
  • the receiver is started again only when it stopped or when the address or the sender check changes; when the integration restarts, Gladys restarts the receiver too and the GEM reconnects by itself. When the receiver runs but does not answer the integration for 3 minutes (another secret, for example after /data could not be read and a new one was made), it is started again, at most every 10 minutes.
Which GEM is followed​
The serial number (the 8 digits the GEM shows) is read in every packet. The first GEM heard is followed and kept in /data; the packets of another serial number are refused and the status says so. After replacing the monitor, type the new serial in Serial number of the GEM: it gets its own devices. What was seen and held for each serial stays in /data under its serial (8 at most): a serial mistyped then corrected keeps every hold. Clearing the field follows the first GEM heard again. When /data cannot be read, no serial is pinned: only a typed serial is followed (the status gives the one heard).
Lifelong counters: never 0, no drop nor jump without you​
The energy index of a channel, its production index and the pulse counters are the values the energy monitoring of Gladys turns into consumption: it counts every rise in full. So:
  • a value of 0 is not published;
  • a value is checked against the last one accepted: not lower, and not more than 100 kWh per hour on average for a channel (100 pulses a second for a pulse counter), plus a small slack;
  • the energy counters of the GEM wrap around at 2^40 watt-seconds (305,420 kWh) and the pulse counters at 2^24 pulses: a wrap (a counter near its top that starts again near 0 while the GEM ran on: its own seconds counter went on with the time elapsed, and the step through the top fits the margin above over those seconds) is counted on; a GEM that restarted (its seconds went back or do not match the time elapsed) never wraps: its drop is held; the offset is kept in /data (a wrap while /data could not keep the previous value shows as a drop, held);
  • a drop (a GEM reset, a replaced CT) or a jump is held back: the last accepted value is sent again, nothing is counted, the status lists the counter with the value held, and the hold is kept in /data across restarts. Time does not lift it, repeating the same value does not either;
  • if it is real, click Accept the held counters twice in the configuration screen: the first click lists exactly what will be taken and accepts nothing; the second, after a few seconds and within 5 minutes, takes exactly those values (a jump is then counted at once as consumption; a drop counts nothing and the counter goes on from there). If the counters held changed in between, nothing is accepted. Saving the configuration accepts nothing.
The checks run on the clock of the integration (the wall clock read once at its start plus the time elapsed since): a wall clock moved by NTP neither widens nor narrows them.
Freshness and status​
  • The values are published when a packet arrives. Packets kept by the receiver while the integration was away are dropped when older than a minute; a repeated packet, or an older one within the same connection (by the GEM's own seconds counter), is dropped. A step back of the seconds counter in a new connection is a restart of the GEM: its packets are taken and the status says so for 10 minutes.
  • A write to /data that does not end within 5 seconds (a frozen disk) is said in the status; the next writes wait behind it, one at most.
  • No packet for 2 minutes (or three intervals of the GEM, up to 15 minutes): the status says how long, the integration is not "connected", and nothing is made up.
  • Gladys accepts 300 values a minute: with many channels and short intervals, the values are sent in turn (the most recent of each), at most 250 a minute.
Limits​
  • One GEM per integration.
  • The settings API of the GEM (CT types, intervals) is not used.
  • Not handled: ASCII packet formats, ECM-1220/1240 monitors, the pulse counters converted into volumes (they are raw counts).
Diese Einstellungen fragt GreenEye Monitor in seinem Konfigurationsbildschirm in Gladys ab.
Your Brultech GreenEye MonitorsectionNeinEnergy (index), power and current of each channel, the voltage, the pulse counters and the temperatures a GreenEye Monitor (GEM) sends, on your local network, without any cloud. The GEM sends its packets to Gladys by itself; nothing is ever sent to it. Give it a fixed IP address in your router. Never tested with a real GEM. Unofficial integration, not affiliated with Brultech.
Address of the GEMstringJaThe IP address of the GreenEye Monitor (the one of its web page), without a port. Nothing listens before it is saved.
How the GEM reaches GladyssectionNeinThe GEM opens the connection itself. In its web page, under the packet sending settings ("Packet Send", TCP client), set the server address to the IP address of the Gladys machine on your network and the port to {{port:gem}} (chosen by Gladys), and a binary packet format: BIN48-NET or BIN32-NET (NET is needed for solar channels), BIN48-NET-TIME, BIN48-ABS or BIN32-ABS. The port exists once the address of the GEM is saved: save, then reload this screen. Allow this port in the firewall of the Gladys machine if it has one.
Check the senderbooleanNeinAccept the connection only from the address of the GEM. Turn it off only if the status says connections come from another address because Docker hides the real one on this machine: then any machine of your network that copies the serial number of the GEM can send false values, which go into the energy indexes. Even on, a machine taking the IP address of the GEM gets through: keep the GEM on a trusted network.
Serial number of the GEMstringNeinOptional: the 8 digits the GEM shows. Empty: the first GEM heard is followed. Packets of another serial number are refused; type the new one after replacing the monitor (it gets its own devices).
Channels, counters and temperaturessectionNeinEach channel is a device with its energy index (kWh, for the energy monitoring of Gladys), its power and its current. A lifelong counter (energy, production, pulses) is never published at 0: a jump or a drop is held back, shown in the status and taken only after two clicks on "Accept the held counters". The pulse counters are published as raw pulse counts.
Channels to showstringNeinOptional, like "1-12, 15". Empty: a channel appears once it measured energy.
Temperature unit set on the GEMselectNeinThe packets do not say it: choose the one of the GEM. °F values are converted exactly to °C. Off: no temperature is published.
Language of the namesselectNein
So installierst du GreenEye Monitor in Gladys​
  1. Öffne in Gladys Integrationen: GreenEye Monitor erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-greeneye:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-greeneye.
GreenEye Monitor benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
GreenEye Monitor ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
