Google Assistant SDK Smart-Home-Integration, kostenlos und Open Source
Unofficial. Broadcast a message on your Google speakers from a scene (Google Assistant API).
Unofficial connector, not affiliated with Google. It uses the Google Assistant API (the "Google
Assistant SDK", gRPC service embeddedassistant.googleapis.com) with your own Google Cloud project,
to broadcast a message on your Google speakers from a Gladys scene: every speaker of the home, or
the speakers of one room.
This integration was never tested with a real Google account or a real speaker: it was written from the official Google sample and the libraries that use it (see
THIRD_PARTY_NOTICES.md), and tested against a fake Google. On 2026-11-10 the API still answered (it refuses an invalid token with the gRPC statusUNAUTHENTICATED), but nothing proves that a broadcast is still played since Google replaced the Assistant with Gemini on part of the speakers. Reports welcome.
What it does
- Scene action "Broadcast on Google speakers": a message (500 characters at most, scene variables allowed) and an optional room (60 characters at most, the name of a room of the Google Home app). The integration asks the Assistant, in the language you chose, the phrase a person would say: in French « Diffuse <message> » or « Diffuse dans <room> <message> », in English "broadcast <message>" or "broadcast to <room> <message>".
- "Test the connection" button: asks the Assistant the time, silently (no speaker plays anything), and shows its answer. It checks the account, the token and the API without disturbing anyone.
- "Send a test broadcast" button: the scene action from the Configuration screen.
What the result of a scene action or a button means:
- "Accepted by Google Assistant.": Google accepted the request. It is not a proof that a speaker played the message: the API gives none.
- "Nothing sent: …": the request did not leave, or Google said it did not run it (refused token, quota, invalid request, API disabled). The scene action fails.
- "Sent to Google Assistant, without confirmation: …": the request left, but no clear answer came back (timeout, connection lost, Google error). The broadcast may have been played. The scene action fails.
Before you start: your Google Cloud project
Google gives no shared key: each user creates their own (free) project.
Open the Google Cloud console and create a project ("Gladys").
Enable the Google Assistant API in this project (direct link).
Google Auth Platform → Get started: app name ("Gladys"), support email, audience External, contact address, accept the terms, Create.
Audience: click Publish app to switch it In production. An app left In testing gets permissions that expire after 7 days (you would have to click Connect every week), and only the accounts listed under Test users can sign in. If you keep it in testing, add your Google account there. No verification by Google is needed for your own use: the app stays "unverified".
Clients → Create client: type Web application, name "Gladys", and under Authorized redirect URIs add exactly:
https://my.gladysassistant.com/redirect/oauth(If you use the Gladys option "use the instance address" on a Gladys served over HTTPS, add the address it shows instead.) Copy the client ID and the client secret.
Configuration in Gladys
- Client ID (ends with
.apps.googleusercontent.com) and Client secret (starts withGOCSPX-). The secret is kept by Gladys in its database, never shown again, sent only to Google. - Assistant language: the language of your Google Assistant (the broadcast phrase is said in it).
- Save, then Connect next to "Google account". Google shows a warning "Google hasn't verified this app": it is your own app, click Advanced → Go to Gladys (unsafe), then allow "Use your Google Assistant". The status turns to "Google account linked."
- Click Test the connection, then Send a test broadcast.
Use the Google account that owns the speakers (the one of your home in the Google Home app). One account per Gladys.
Limits and behaviour
- One request at a time to Google, at least 1 s apart, at most 30 in 10 minutes, and 5 broadcasts waiting at most: a scene that loops gets "Nothing sent" instead of flooding Google.
- Each broadcast answers within 25 s, waiting included (Gladys waits 30 s for a scene action): a broadcast stuck behind slow ones gets "Nothing sent: the broadcasts before it took too long."
- Google asks to slow down (quota, HTTP 429, or a server error): every request to Google pauses 60 s, then 2, 4… minutes up to 6 h if it happens again (or the longer delay Google gives), kept across a restart. The status shows when requests resume, and is updated when the pause ends. Only a success of the Assistant resets the doubling (a token renewal says nothing about its quota); Connect is refused during a pause. At the end of a pause, if the access token has expired, the integration renews it once by itself (to show a true status): one request, spaced by the doubling.
- Google refuses the access (revoked, password changed, app still "In testing" for more than 7 days) or refuses the client ID or secret: the integration stops asking and the status says so. This holds after a restart. It is lifted by Connect (a new authorization) or by a changed client ID or secret.
- Any other error of the token endpoint (unreadable answer, another HTTP error, no network) is not a refusal: the next renewal waits 5 s, then 10, 20 s… up to 1 h.
- The access token (1 h) lives in memory only; a request made less than 5 minutes before it expires renews it first. A renewal that does not end within the 25 s of the broadcast gives "Nothing sent". If Google refuses a cached access token, it is renewed once and the request is sent again; a refused fresh token is reported ("did not accept a fresh access token"), not taken for a refused account.
Known limits of the Google Assistant SDK (also listed by Home Assistant's integration):
- Broadcasting to a room often fails outside English; leave the room empty to reach every speaker.
- Speakers in Do not disturb mode stay silent.
- The API no longer returns text answers: "Test the connection" usually shows "without text", which is normal.
- With Gemini on the speakers, Google acknowledged in 2026 a bug where a broadcast is answered as a question instead of being played.
- The scope
assistant-sdk-prototypeis the one of the official samples: Google may close it.
What is stored where
- In the Gladys configuration: the client ID, the client secret and the refresh token written after Connect (an off-form key, never shown in the interface, never sent to the browser, sent only to Google). The access token is never stored.
- In
/data/google-assistant.json: the end of a pause asked by Google, and, after a refusal only, an 8-bit salted fingerprint of the refused credentials (it can tell "maybe the same" but never rebuild a token). Nothing else. - The authorization code passes through the static Gladys page
my.gladysassistant.com/redirect/oauthon its way back to your Gladys (see the Gladys documentation); it is useless without your client secret, which only goes from your Gladys to Google. No token passes through it. - No token, secret or authorization code in the logs, the status or the error messages.
To remove the access: myaccount.google.com/permissions → your app → Remove access.
- "Error 400: redirect_uri_mismatch": the authorized redirect URI of the OAuth client is not
https://my.gladysassistant.com/redirect/oauthexactly (no trailing slash), or the client is not of type Web application. - "Error 403: access_denied": the app is "In testing" and your account is not a test user. Publish it, or add your account under Test users.
- "Google refused the access … Click Connect again." every week: the app stayed "In testing". Publish it, then click Connect.
- "Google Assistant refused the request … Is the Google Assistant API enabled?": enable the Google Assistant API in the project of the OAuth client, wait a few minutes, test again.
- "Google did not hand a refresh token": Google only gives one at the first consent. Remove the access of your app (link above), then click Connect again.
- Accepted, but no speaker plays: check Do not disturb, the Google account (the one of the home), the room name, and try an empty room. On a speaker that runs Gemini, the broadcast may be answered instead of played (Google bug, outside this integration).
Diese Einstellungen fragt Google Assistant SDK in seinem Konfigurationsbildschirm in Gladys ab.
| Your Google Cloud project | section | Nein | Unofficial connector, not affiliated with Google. Google offers no shared key: create a free Google Cloud project, enable the Google Assistant API, set up the consent screen (External) and publish it “In production” (otherwise the access expires after 7 days), then create an OAuth client of type “Web application” whose authorized redirect URI is exactly https://my.gladysassistant.com/redirect/oauth. The documentation details every step. |
| Client ID | string | Ja | Ends with .apps.googleusercontent.com. |
| Client secret | secret | Ja | Shown by Google when the client is created (it starts with GOCSPX-). Kept by Gladys in its database, never shown again, sent only to Google. |
| Assistant language | select | Ja | The language of your Google Assistant: the broadcast command is said in it. |
| Google account | oauth2 | Nein | Save the fields above first, then click Connect and allow “Use your Google Assistant”. The refresh token is kept by Gladys in its database, never shown, sent only to Google. |
So installierst du Google Assistant SDK in Gladys
- Öffne in Gladys Integrationen: Google Assistant SDK erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/lm1lc3n7/gladys-google-assistant-sdk:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-google-assistant-sdk.
Google Assistant SDK benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Google Assistant SDK ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
