GO Transit Smart-Home-Integration, kostenlos und Open Source
GO Transit-Integration für Gladys Assistant
GO Transit (Toronto region): next departures, delays and service alerts.
The next departures of your GO Transit stations (Toronto region), their delays and platforms, and the service alerts of the network, from the official GO API of Metrolinx.
Contains information licensed under the Open Government Licence – Ontario – Metrolinx (licence). This integration is not affiliated with Metrolinx. It was never tested with a real key: the formats come from the API documentation (help pages and samples), and the first users may meet a field the samples did not show.
1. Get a key​
  1. Fill in the registration form of the GO API (free). Metrolinx handles the requests by hand: up to ten business days.
  2. The key arrives by e-mail. It does not expire, but Metrolinx switches off a key that calls too much, by hand. The integration therefore keeps to its own limits (below).
2. Configure​
  • GO API key: paste the key. Kept by Gladys in its database, never shown again, sent only to api.openmetrolinx.com (in the address of each call, as the API asks), never written in the logs, the status or the integration files.
  • Stations and stops: the GO stop codes, comma-separated, 6 at most: UN for Union Station, OA for Oakville… The Find a stop button at the bottom of the page gives the codes (it reads the list of stops once, then keeps it a week; at most one read every 30 s). After the code, an optional line filter (@LW, several joined by +: @LW+LE) and a name (:Oakville to work): UN, OA@LW:Oakville to work.
  • Watch the service alerts: proposes the alerts device. Lines of the alerts: only the alerts of these lines (LW, LE); empty, every alert.
  • Advanced: the refresh of the departures (60 s by default, 60 s at least), of the alerts (300 s, 120 s at least), the number of departures per station (1 to 5), the language of the values (the alerts come in English and French from Metrolinx).
Then open the Discover tab and add your stations and the alerts device. Only the devices you added are read: a station left in the Discovery screen costs nothing.
3. What you get​
For each station:
  • Next departure, Departure 2…: minutes to wait. 999 = no departure or no recent reading, see the status text (empty, or No recent reading). A scene comparing the minutes should exclude 999.
  • … line: line and direction (LW - Aldershot GO).
  • … status: On time, +5 min, 2 min early, Cancelled, or Scheduled when the API gives only the timetable time; then the platform when known (Pl. 4).
  • Next departures: one line for a dashboard (LW 17:23 +5 min · Pl. 4 | LE 17:30 On time), in Toronto time.
The alerts device: Active alerts (number, of the watched lines) and Latest alert (its subject).
The GO departures dashboard widget shows the board of a station, counted down from the last reading.
When a station has not been read for 15 minutes (or twice its refresh interval, when longer), its countdowns go to 999, the line texts are emptied, and the status texts and Next departures say No recent reading; the widget shows nothing either. This also applies after a restart that cannot read (pause, refused key). A departure board whose own time is more than 10 minutes away from the Date header of the answer is an old snapshot: neither published nor used for the scenes, and the status says so. Without that header the board is used as it is (the clock of the Gladys host is not trusted for this). The alerts are not checked this way.
Scenes​
  • GO departure delayed: a departure of a station is late by at least 5, 10, 15 or 30 minutes, or is cancelled. Once per departure and per threshold (a departure that goes from 0 to 12 minutes fires 5 and 10). Filters: station, event, threshold, line. Variables: line, direction, trip number, delay, minutes to wait, times, status.
  • New GO service alert: Metrolinx posted an alert for a watched line, one event per line of the alert (5 at most). The first reading after installing only learns the alerts already there, so you do not get them all at once. The alerts already announced are remembered across restarts.
4. Limits kept by the integration​
  • One call at a time, and 450 calls per rolling hour at most, all together, counted before each call and kept across restarts (6 stations every minute and the alerts every 5 minutes make 372).
  • Each source is read once per its interval, restarts included.
  • After a 429, a 5xx, no answer within 10 s or an unreadable answer: every call pauses 1 minute, then 2, 4… up to 6 hours (Retry-After honored), kept across restarts. A success resets the ladder.
  • Answers bounded: 512 KB (2 MB for the list of stops), cut beyond.
  • Key refused (403 while the key has read nothing else, or 401): reads stop, and the status says so. Kept in /data as 8 bits of a salted hash, never the key. Lifted by a new key or a successful Test the key click. Saving the same key again does not send it again. Rare limit: after a restart, a new key whose 8-bit mark matches the refused one (1 chance in 256) waits for one click on Test the key.
  • A 403 on one kind of data while the key reads the other (the key lost one right): only that kind waits, 2 minutes doubled up to 1 hour.
  • Test the key: once a minute at most; it counts in the hourly limit and is not sent during a pause (the answer says so).
  • A stop code the API does not know is asked again every 30 minutes, and named in the status.
  • /data unreadable: no call until it can be read (read again every 10 s); nothing written over it.
5. Status messages​
The Configuration screen says what to do next: add the key, key refused, pause and its length, hourly limit reached, codes ignored, stations unknown to the API, no access to the alerts.
Privacy​
The only service called is api.openmetrolinx.com. The location of your house is never read.
Diese Einstellungen fragt GO Transit in seinem Konfigurationsbildschirm in Gladys ab.
Get startedsectionNein1. Ask Metrolinx for a free GO API key (link below; it arrives by e-mail). Metrolinx handles requests by hand, up to ten business days. 2. Paste it here and type the codes of your stations (UN for Union Station; the “Find a stop” button at the bottom gives the others). 3. Save, then open the “Discover” tab and add your stations and the alerts device. Contains information licensed under the Open Government Licence – Ontario – Metrolinx. Not affiliated with Metrolinx. Never tested with a real key.
GO API keysecretJaThe access key Metrolinx sent you. Kept by Gladys in its database, never shown again, sent only to api.openmetrolinx.com. Metrolinx switches off a key that calls too much: the integration keeps under 450 calls an hour. If Metrolinx refuses the key, reads stop until you change it or click “Test the key”.
Stations and stopsstringNeinGO stop codes, comma-separated, 6 at most (each one costs a call per refresh). Optional line filter after @ (several joined by +) and name after : — e.g. “UN, OA@LW:Oakville to work”.
Watch the service alertsbooleanNeinProposes a “GO Transit – Service alerts” device: the number of current alerts and the latest one.
Lines of the alertsstringNeinOnly the alerts of these lines (codes, comma-separated). Empty: every alert of the network.
AdvancedsectionNeinThe defaults suit almost everyone and keep the key well under the limits of Metrolinx.
Departures refresh (s)numberNeinSeconds between two reads of each station.
Alerts refresh (s)numberNeinSeconds between two reads of the service alerts.
Departures per stationnumberNeinHow many upcoming departures each station device shows.
Language of the valuesselectNeinLanguage of the feature names, the statuses and the alerts (Metrolinx writes them in both).
So installierst du GO Transit in Gladys​
  1. Öffne in Gladys Integrationen: GO Transit erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-go-transit:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-go-transit.
GO Transit benötigt Gladys >=5.3.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
GO Transit ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
