Fujitsu Airstage & FGLair Smart-Home-Integration, kostenlos und Open Source
Fujitsu air conditioners of the Airstage and FGLair apps: mode, setpoint, fan, swing, eco…
Fujitsu air conditioners and air-to-air heat pumps with Wi-Fi are controlled with one of two Fujitsu apps: Airstage (the current one, with the newer units and Wi-Fi adapters) or FGLair (the older Wi-Fi modules, still common in Europe). This integration brings the units of either app into Gladys: turn them on and off, change the mode, the setpoint, the fan and the swing, use the economy, powerful and outdoor low-noise modes, and follow the indoor and outdoor temperatures. Airstage units can also be controlled locally, through their Wi-Fi adapter, without the cloud.
Unofficial: not affiliated with Fujitsu General.
Development version (0.1). Written from the projects that Homebridge and Home Assistant users run with these units (see Credits), and checked against their data; not yet tested with a real Fujitsu unit or account. Your feedback is welcome on the GitHub repository.
Which units
| Your app | What to fill in | How Gladys reaches the unit |
| FUJITSU AIRSTAGE (Airstage Mobile) | the Airstage account, and/or the address of the unit's Wi-Fi adapter | the adapter on your network, or the Airstage cloud (Europe or US) |
| FGLair | the FGLair account | the FGLair cloud (Europe, or the other regions) |
- Both apps can be used at the same time: fill in both accounts.
- Not covered: Atlantic units of the Cozytouch app (use the Overkiz integration of the store), and Fujitsu units without Wi-Fi or on another controller (KNX, Modbus, Intesis…).
One Gladys air conditioner per indoor unit, with the features the unit has (Fujitsu says which: a unit without a setting gets no feature for it):
| Feature | In Gladys |
| On/off | air conditioner on/off |
| Mode | auto, cool, heat, dry, fan |
| Setpoint | 16 to 30 °C in heat, 18 to 30 °C otherwise, half degrees |
| Fan speed | auto, quiet, low, medium, high |
| Vertical swing | off, swing, and the fixed positions (up to 4) |
| Vertical position | position 1 (top) to 6 or 8 (bottom), on the units with 6 or 8 positions |
| Horizontal swing | off, swing |
| Economy, Powerful | switches |
| Outdoor unit low noise | switch |
| Energy saving fan | switch (Airstage) |
| Minimum heat (10 °C) | switch (Airstage): heat at 10 °C to keep the room from freezing |
| Indoor, outdoor temperature | temperature sensors (°C) |
| Error code | text, read only (Airstage) |
Like in the apps: dry mode sets the fan to auto, a fixed vertical position stops the vertical swing, the minimum heat mode turns the unit on in heat at 10 °C (and off when it stops). With FGLair, choosing a mode also turns the unit on, and turning it on goes back to its last mode.
- Check that your units work in the Airstage or FGLair app.
- In the configuration of the integration, fill in what you use:
- Airstage app: the e-mail and the password of the app, the region
(Europe for an account created in Europe) and the country of the account,
in English as chosen in the app (
France,Belgium,Switzerland…). - Airstage Wi-Fi adapters (optional): one entry per unit, separated by
commas: its IP address, its MAC address, and a name if you want, for
example
192.168.1.20 E8:FB:1C:12:34:56 Living room, 192.168.1.21 E8:FB:1C:65:43:21. Give each adapter a fixed IP address in your router. The MAC address is on the label of the adapter and in your router; for a unit already found through the Airstage cloud, it is also in the device page of Gladys. Adapters that answer in HTTPS are found on their own; writehttps://192.168.1.20to force it. - FGLair app: the e-mail and the password of the app, and the region (Europe, or the other regions).
- Save, then click Test the connection: each account lists its units, each adapter answers with its model.
- Open the Discovery tab and add your units.
Options
| Option | Default | Purpose |
| Airstage region | Europe | the Airstage cloud of the account (Europe, United States) |
| Country of the Airstage account | France | sent at sign-in, as the app does |
| FGLair region | Europe | the FGLair cloud of the account (Europe, other regions) |
| Language of the feature names | French | names of the features and of their options |
| Prefer the local connection | on | Gladys toggle: an Airstage unit with an adapter in the list goes through it, the cloud as a fallback; off: the cloud first |
How it works
- Airstage adapters: Gladys reads each adapter on your network every 30 seconds and sends the commands to it. The integration container runs on a bridge network, so the adapters are reached by their IP address (no automatic discovery).
- Airstage cloud: the units and all their settings are read every 2 minutes; a command is sent as a request that the cloud passes to the unit, and Gladys follows it until the unit took it.
- FGLair cloud: the settings of each unit are read every 5 minutes, and a few seconds after a command. FGLair has a local mode too, but it needs the unit to call Gladys back, which the integration container cannot receive.
- The sign-ins are kept in the
/datafolder of the integration, so a restart of Gladys does not sign in again. The passwords are never written there. A refused password is never retried on its own: fix it and save. - The transport badge of each unit shows local (through its adapter), cloud, or unreachable. An orange dot means the unit went through the other way because its usual way failed (adapter unreachable, cloud down).
- "the e-mail or the password was refused": check them in the app, and the region (an account created in Europe is on the Europe cloud), then save.
- An adapter is unreachable: check its IP address (fixed in your router), that Gladys and the unit are on the same network, and the MAC address: a wrong MAC makes the adapter answer "NG 0002".
- Adapter entries not understood: each entry needs an IP address (or a host name with a dot) and a MAC address.
- The setpoint is refused: 16 to 30 °C in heat, 18 to 30 °C in the other modes; it cannot be set in fan mode.
- "too many requests": the cloud slows Gladys down; it tries again after the delay the cloud asks for, up to one hour.
- "HTTP 422 … t_device_feature.min cannot be null" when adding a unit (versions 0.1.1 and earlier): Gladys refused the "Vertical position" list (units with 6 or 8 positions) or the "Error code" (Airstage), and with it the whole unit. Update the integration, then add the unit again from the Discovery tab. Gladys saved nothing of the refused unit: there is nothing to delete.
Credits
The Airstage cloud and adapter protocol comes from
homebridge-fujitsu-airstage
by Patrick Stankard (MIT) and pyairstage
by Daniel Rufus Kaldheim (MIT), the library of the
ha_airstage Home Assistant
integration. The FGLair protocol comes from
ayla-iot-unofficial (MIT),
the library of the Home Assistant fujitsu_fglair integration, and
pyfujitseu (MIT), cross-checked with
homebridge-fujitsu-hvac
(MIT). See the NOTICE file of the repository.
Diese Einstellungen fragt Fujitsu Airstage & FGLair in seinem Konfigurationsbildschirm in Gladys ab.
| Your Fujitsu air conditioners in Gladys | section | Nein | The Fujitsu air conditioners and air-to-air heat pumps of your Airstage app (newer units and Wi-Fi adapters) or FGLair app (older units) are offered in the Discovery tab: on/off, mode, setpoint, fan speed, vertical and horizontal swing, economy, powerful and outdoor low-noise modes, minimum heat, indoor and outdoor temperatures, error code, as the unit supports. Fill in the account of your app, and for Airstage units also the address of their Wi-Fi adapter to control them locally, without the cloud. Atlantic units of the Cozytouch app are covered by the Overkiz integration. Unofficial, not affiliated with Fujitsu General. |
| Airstage app | section | Nein | The e-mail and password of the Fujitsu Airstage app. Leave empty if you only use FGLair or the local adapters. |
| Airstage e-mail | string | Nein | |
| Airstage password | secret | Nein | |
| Airstage region | select | Nein | |
| Country of the Airstage account | string | Nein | In English, as chosen in the app (France, Belgium, Switzerland…). |
| Airstage Wi-Fi adapters on the network | section | Nein | Optional: Gladys then talks to the adapter directly on your network, faster and without the cloud. One entry per unit, separated by commas: its IP address, its MAC address, and a name if you want, for example "192.168.1.20 E8:FB:1C:12:34:56 Living room". Give the adapter a fixed IP address in your router. The MAC address is on the label of the adapter, in your router, or in the device page of Gladys for a unit found through the Airstage cloud. |
| Adapters (IP MAC name, …) | string | Nein | |
| FGLair app | section | Nein | The e-mail and password of the Fujitsu FGLair app (older Wi-Fi modules). Leave empty if you only use Airstage. |
| FGLair e-mail | string | Nein | |
| FGLair password | secret | Nein | |
| FGLair region | select | Nein | |
| Language of the feature names | select | Nein | The names of the features and of the options (modes, fan speeds, positions) of the discovered devices. |
So installierst du Fujitsu Airstage & FGLair in Gladys
- Öffne in Gladys Integrationen: Fujitsu Airstage & FGLair erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/lm1lc3n7/gladys-fujitsu:0.1.2) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-fujitsu.
Fujitsu Airstage & FGLair benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Fujitsu Airstage & FGLair ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
