Enphase IQ Gateway Smart-Home-Integration, kostenlos und Open Source
Enphase IQ Gateway-Integration für Gladys Assistant
Local monitoring of your Enphase IQ Gateway: production, consumption and micro-inverters.
This integration monitors your Enphase solar installation locally: production, consumption (when a meter is present), battery (when an IQ Battery is installed), the individual production of every micro-inverter, the IQ System Controller and the CT meters.
Prerequisites​
  • An IQ Gateway with D8+ firmware (November 2023 or later).
  • The gateway reachable from the same local network as your Gladys instance.
  • A local access token: on the gateway web UI, go to System > Local Access, sign the Enphase agreement and copy the displayed JWT token.
  1. Install the integration from the Gladys catalog.
  2. Enter the gateway local IP address (or click “Detect gateway”, which finds it over mDNS).
  3. Paste your local access token.
  4. Choose the refresh interval (15 to 600 seconds, 60 by default).
  5. Enable “Monitor each micro-inverter” to get one device per inverter.
The integration makes no cloud calls: everything stays on your local network.
Published devices​
Values are published in kW / kWh (power / energy), % (battery level), °C (temperature), V (voltage) and A (current), rounded to 3 decimal places maximum.
  • One “gateway” device: production (kW), today / last 7 days / lifetime production (kWh), consumption (kW and kWh/day) when a meter exists, and battery (level %, charge/discharge power, remaining energy) when an IQ Battery is installed.
  • One device per micro-inverter (when enabled): instantaneous power (kW) and a text status (“Active”, “Offline…”) to spot a failing inverter.
  • One device per IQ Battery (Encharge): level (%), temperature (°C), power (kW) and capacity (kWh).
  • One “IQ System Controller” device (Enpower): grid mode, temperature (°C) and admin state.
  • One device per CT meter: active power (kW), delivered / received energy (kWh), voltage (V) and current (A).
The Encharge, Enpower and CT meter devices are only published when the gateway reports them (automatic detection).
Security: pin the gateway certificate​
The gateway uses a self-signed certificate, so the integration cannot cryptographically prove its identity by default. Anyone able to impersonate the gateway on your local network could in theory capture your access token.
Recommended: fill in the “Gateway certificate fingerprint (optional)” field. The integration then only trusts a gateway that presents exactly that certificate — an impostor is rejected (CERT_PIN_MISMATCH) even though TLS validation stays relaxed.
  1. From a trusted machine on the same network, read the real gateway's fingerprint:
    openssl s_client -connect <gateway_ip>:443 \
    < /dev/null 2>/dev/null | \
    openssl x509 -noout -fingerprint -sha256
  2. Copy the SHA256 Fingerprint=... value into the Gateway certificate fingerprint field.
  3. Save — the pin is applied immediately. Case and separator spacing don't matter (the code normalises them).
If the gateway's certificate ever changes (firmware update, hardware replacement), the integration will refuse to connect: re-read the new fingerprint and update the field.
Note: the pin protects every connection made after it is set. Always read the fingerprint from your own, trusted gateway — never through an intermediate source.
  • “Token refused”: the token is invalid, expired or revoked. Regenerate it in the gateway menu (System > Local Access).
  • “Gateway unreachable”: check that the gateway is powered, on the same network, and that the IP is correct (the “Detect gateway” button finds it over mDNS).
  • “Detect gateway” finds nothing: the gateway advertises several addresses over mDNS, including IPv6 ones. The integration only keeps a private address (IPv4 first) and never sends the token to a public address — if no private address is advertised, enter the gateway's LAN IP manually.
  • No consumption shown: your installation has no consumption meter connected — the integration only publishes data the gateway actually reports.
  • Certificate fingerprint rejected: the gateway certificate changed or a device is trying to impersonate the gateway. Re-read the real fingerprint and update the field.
  • The transport badge stays local when all is well, and switches to unreachable when the gateway stops answering.
Diese Einstellungen fragt Enphase IQ Gateway in seinem Konfigurationsbildschirm in Gladys ab.
Getting startedsectionNeinGenerate a local access token on your IQ Gateway (firmware D8+): from the gateway web UI, go to System > Local Access, sign the Enphase agreement and copy the token. The integration reads it directly on your local network — no cloud account needed.
Gateway IP addressstringJaThe local IP address of your IQ Gateway, e.g. 192.168.1.42. Use the "Detect gateway" button to find it on your network.
Local access tokensecretJaThe JWT token generated in the gateway web UI (System > Local Access). It is stored encrypted by Gladys and never sent to the frontend.
Refresh interval (s)numberNeinHow often the gateway is polled, in seconds. Production data updates every 5 seconds on the gateway; a 15-60 s poll is a good balance.
Monitor each micro-inverterbooleanNeinPublish one device per micro-inverter with its current production, to spot a failing unit (a dead inverter reports 0 W).
Gateway certificate fingerprint (optional)stringNeinOptional SHA-256 fingerprint of the gateway's certificate (e.g. AB:CD:12:34:…). When set, the integration only trusts a gateway whose certificate matches it — the recommended defense against a device impersonating your gateway on the local network. Get it from your browser's certificate view, or with: openssl s_client -connect <gateway_ip>:443 < /dev/null 2>/dev/null | openssl x509 -noout -fingerprint -sha256.
So installierst du Enphase IQ Gateway in Gladys​
  1. Öffne in Gladys Integrationen: Enphase IQ Gateway erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/echopouet/gladys-enphase:1.0.3) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/EchoPouet/gladys-enphase.
Enphase IQ Gateway benötigt Gladys >=4.86.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Enphase IQ Gateway ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von EchoPouet veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
