Eloverblik (Denmark) Smart-Home-Integration, kostenlos und Open Source
Eloverblik (Denmark)-Integration für Gladys Assistant
Unofficial: consumption of your Danish electricity meters through Eloverblik.
Unofficial integration, not affiliated with Energinet nor with Eloverblik. It reads the hourly electricity consumption of your Danish metering points through the official customer API of Eloverblik (Energinet DataHub) and feeds the energy monitoring of Gladys with it. Read-only: nothing is ever changed on your account.
This integration has never been tested with a real Eloverblik account: it is written from the official API description (Swagger). Feedback is welcome.
What you need​
  • A Danish electricity metering point (consumption) and MitID to log in to eloverblik.dk.
  • Gladys 5.3.0 or later.
Create the token​
  1. Log in to eloverblik.dk with MitID (private customer).
  2. Make sure your metering points are linked to your account (they appear on the home page).
  3. Open the Data sharing menu (Datadeling), then create a token for the API. Give it a name, for example "Gladys", and copy it: it is a long text in three parts separated by dots, shown only once.
  4. In Gladys, open the integration, paste the token in Eloverblik token and save.
The token is valid for one year. The status of the integration shows the date it ends: create a new one on eloverblik.dk before that date and save it in Gladys.
The token is kept by Gladys in its database, never shown again, and sent only to Eloverblik (api.eloverblik.dk). It is never written in the logs, the status nor /data.
Create the devices​
After saving, the integration lists your consumption metering points (type E17; production points are not read, 10 points at most). Open Discovery and create the devices you want: each one is named "Eloverblik meter …1234" (the last 4 digits of the metering point id only) and has a single feature, Consumption (30 min).
Only the created devices are read. The Test the token button asks for an access token and lists your points (at most once a minute).
How the data arrives​
  • Eloverblik publishes the consumption one or two days late. The integration reads once a day, from 09:00 (Danish time, a minute proper to your installation, up to 12:00), and asks only for the days not yet complete. While yesterday is incomplete, it reads again 4 hours later, 4 scheduled reads a day at most. A device created, a new token or a Test that succeeds brings a read a minute later on top of them; the reads always stay an hour apart otherwise, and within 30 requests a day.
  • At the first read, it takes 31 days back, never before the day the metering point became yours (consumerStartDate of Eloverblik). If DataHub answers that the period starts before its registration (30018) or before the authorization (30010), that point's first accepted day is searched alone, by halves down to the day (no day lost), 8 requests at most per read for all the points (one more, once per run, if DataHub refuses quarter hours during a search); a search cut there publishes nothing yet (status start_search) and goes on at the next read. Each distinct start is asked in its own request, so a recent point never makes the others fail. After a stop, it catches up at most 92 days back. The last 3 complete days are read again with the next days: an estimated value replaced by a measured one is corrected.
  • The integration asks for quarter hours and adds them two by two (the energy monitoring of Gladys works by half hours); when DataHub refuses that aggregation (30008, 30011), it asks for hours and splits each one in two equal half hours (until a restart). A half hour with a missing quarter stays unknown. An hour Eloverblik marks as not available (quality A02) or incomplete (A05) stays unknown: it is never counted as 0. A day with a missing hour is asked again for 10 days, then given up.
  • The consumption goes into the energy monitoring with the date of each half hour (publishEnergyConsumption): there is no cumulative index, and no live value.
Costs and energy contracts​
This integration has no contract of its own. To see costs, attach an energy contract to the consumption in Gladys, for example the Danish contract of the Energi Data Service integration (grid tariffs, Energinet, elafgift and DK1/DK2 spot prices). Danish tariffs that depend on the hour need the 30-minute consumption: this is what this integration publishes.
Limits of the Eloverblik API​
The integration stays far below the published limits: at most 30 requests a day, one at a time, 2 seconds apart; the data access token (valid 24 hours) is kept in memory and renewed after 20 hours; two token requests are never closer than 5 minutes, even after a restart (the time is kept in /data; the limit is 2 a minute per IP).
  • 429 (too many requests) or 503 (DataHub unavailable) and other 5xx: every request pauses: 15 minutes, doubled each time up to 6 hours, or the Retry-After of the answer when it is longer (6 hours at most). The pause survives a restart.
  • Refused token (the token request answers a 401 or 403 with an empty body, a JSON body or a WWW-Authenticate: Bearer header, or one of the error codes 50000 / 50001; a non-empty HTML page of a proxy is not a refusal): nothing is asked any more; the status says so. Save a new token, or press Test once the token works again.
  • A 401 or 403 on a data route is not a refusal of your token: the access token is dropped and a new one is asked at the next read.
  • An error on one metering point (no data, relation expired, ...) is shown in the status with its code (for example E30015); that point is asked again the next day only, the other points go on.
What /data keeps​
/data/eloverblik.json keeps: the time of the last read and of the last token request, the count of requests of the day, the pause, a mark of a refused token (8 bits of a salted hash, nothing to find the token back from) and, per metering point (named by a keyed hash, never its id), the last complete day.
  • "Eloverblik lists no consumption metering point": link your metering points on eloverblik.dk (the token only sees the points linked to your account).
  • "Meter …1234: E20010" (relation not found) or E30016 (relation expired): link the metering point again on eloverblik.dk.
  • "E30015": no data for the period yet; it is asked again the next day.
  • "not_listed": a created device is no longer among the metering points of the token.
  • The Gladys time zone should be the Danish one (or the same clock): the days are Danish days.
Data source​
Data: Eloverblik, Energinet DataHub, your own meter data, read with the token you created.
Diese Einstellungen fragt Eloverblik (Denmark) in seinem Konfigurationsbildschirm in Gladys ab.
Eloverblik tokensectionNeinUnofficial connector, not affiliated with Energinet. On eloverblik.dk, log in with MitID, link your metering points, then create a token (Data sharing / API). The integration reads, once a day, the consumption of every metering point you create in Discovery; Eloverblik serves it one or two days late, so the energy monitoring of Gladys fills up after the fact (quarter hours added two by two, or each hour in two half hours). Read-only. The token is valid for a year: create a new one before it ends (the status shows the date). For the costs, pair it with an energy contract (for example the Energi Data Service integration for Danish tariffs and spot prices).
Eloverblik tokensecretJaThe token created on eloverblik.dk (a long text in three parts separated by dots). Kept by Gladys in its database, never shown again, sent only to Eloverblik (api.eloverblik.dk).
So installierst du Eloverblik (Denmark) in Gladys​
  1. Öffne in Gladys Integrationen: Eloverblik (Denmark) erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-eloverblik:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-eloverblik.
Eloverblik (Denmark) benötigt Gladys >=5.3.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Eloverblik (Denmark) ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
