Eco-Devices 3 Smart-Home-Integration, kostenlos und Open Source
Eco-Devices 3-Integration für Gladys Assistant
GCE Eco-Devices 3: energy, water and gas counters, current clamps, relays, X-THL sensors.
Brings up to three GCE Electronics Eco-Devices 3 (ED3) into Gladys through their local HTTP API: their counters (teleinfo, consumption, production, injection, storage, water, gas), the power of their current clamps, the mains voltage, their two relays, the outputs of their X-8R extensions and their X-THL sensors (temperature, humidity, luminosity).
Readings checked against a real ED3: cce66's, a member of the Gladys forum (firmware 1.3.0), who recorded its answers; they are replayed in the tests: its MAC address (an invented one of the same form in the tests), its counters and the clamps and pulse inputs feeding them, the units of the teleinfo, clamp and water counters, the clamp power. The commands (relays R1 and R2) were not tested on a real device, and no X-8R nor X-THL extension has been seen on a real ED3 yet. Written from GCE's documentation of the ED3 API (Postman "API ED3", linked from the ED3) and cce66's free tools (ED3 Api-Deck and Mqtt-Deck). Tell us what you see on yours. Not affiliated with GCE Electronics.
Setup​
  1. In the ED3, Configuration menu: set an API key and note it.
  2. In Gladys, Integrations > Eco-Devices 3: type the address of the ED3 (e.g. 192.168.1.60, with :port only if you changed the port of its web server; give it a fixed address in your router) and the API key. On the same page, list in "Relays Gladys may drive" the relays Gladys must drive, and only those (R1, R2; see "Relays" below: never a pump, a ventilation, a door strike…). Then save.
  3. "Test the connection" reads the ED3 at once (once an interval has passed since the last read) and shows what it found.
  4. In Discover, create the devices you want. A listed relay comes as a switch (or a light); the others come read only ("State (read only)"): Gladys shows their state, nothing can switch them.
A relay listed after its creation stays read only until you click "Update" on it in Discover: it then gets its switch (or light), next to its "State (read only)", which stays. The status of the integration says how many relays are read only while none is listed, and which listed relays still wait for "Update".
The ED3 wants the API key in the address of every request, over plain http: anyone who can watch your local network can read it, as with the ED3's own page. The key is kept by Gladys in its database, never shown again, sent only to the ED3, and never written in the logs nor in the files of the integration.
If the address answers as another GCE box (an IPX800 V5, an IPX800 V4 or an Eco-Devices RT2), the status and "Test the connection" say so: no value is published and no command is sent, not even a switch-off, and the switch-offs kept are dropped. Use the integration of that box.
On the ED3In GladysCode (in the name)
Relays 1 and 2read only, or a switch / light when you list itR1, R2
Output of an X-8Rread only (state)X8R4259840-3
Counter 0 (teleinfo total)consumption index (kWh), counted by Gladys (energy and cost)C0
Counters 11 to 18 (consumption) (¹)consumption index (kWh), counted by Gladys (energy and cost)C11
Counters 20 and 21 (production) (¹)production index (kWh), counted by GladysC20
Counter 19 (injection) (¹)index of the energy fed into the grid (kWh), shown onlyC19
Counters 1 to 10 (teleinfo tariffs)plain sensor "Tariff index (kWh)", never counted twiceC1
Counters 22 to 24 (storage) (¹)plain sensor "Storage index (kWh)"C22
Counters 25 to 27 (water), 28 and 29 (gas)volume (m³), out of the energy monitoringC25, C28
Clamp linked to a counterpower (W), signed (²)T1
Supply voltagevoltage (V)U
X-THLtemperature (°C), humidity (%), luminosity (lux)XTHL4325376
The counter numbers are the ED3's (GCE assigns them by category). A counter fed by a clamp or a pulse input is named after it in Discover, as the ED3 lists them (ID_Logger_tore, ID_Logger_tore_neg, ID_Logger_pulse, ToreName, PulseName): "T1-EDF · Consumption (C11)", "T1-EDF (negative) · Injection (C19)" for the counter of the clamp's other direction, "Eau · Water (C25)". The others take the name you gave the counter on the ED3 (read again every 10 minutes). A name changed later on the ED3 does not rename a device already created. A counter at 0 (not set up, or not read by the ED3 yet) is not offered; a clamp that feeds no counter (0 in both lists) neither. The ED3 may list fewer than 30 counters (a real one listed 26): a counter is known by its ED3 id, never by its place in the list, and one not listed is not offered.
Units: the teleinfo and clamp indexes are in Wh on the ED3, published in kWh. Checked on a real one: its counter 0 (teleinfo) matched, within a few minutes, the same Linky read by an Eco-Devices RT2; the counter of its battery clamp grew at 56.7 W on average over 71 hours in Wh, while the clamp read about 60 W at both readings (57 W on average at the first; 64 W from its power and 59 W in the ED3's page data at the second): in mWh it would be 0.06 W. That second reading came from address .161, the others from .162 (the same ED3 by its indexes; asked). Water and gas in mL, published in m³: compared with a real water meter (61,503.0 L on the meter, 61,503,000 on the ED3). When the ED3 gives ID_Logger_pulse (the counters its pulse inputs feed), an electricity counter fed by a pulse input is not offered (its unit is not checked; the status names it), nor one listed both by a clamp and by a pulse input. Without that list (absent: an older firmware), which counters the pulse inputs feed is not known, and such a counter is published in kWh as any other, its unit not checked. When the ED3 gives that list in another form (another firmware), no electricity counter that a clamp is not known to feed is offered, the teleinfo (C0 to C10) included, and one already created in Gladys is no longer updated while it lasts (the status names them). The counters 11 to 24 are not offered when a clamp is linked to a counter outside 11 to 24 (see (¹)).
The ED3 is read every 15 seconds by default (10 s at least). A value the ED3 does not give (absent, a text, out of range, a voltage of 0 V) is not published: never as 0. An X-THL reporting a measurement fault (ioFault) publishes nothing while it does, and the status names it. An X-8R or X-THL without an extension code (an object created, nothing paired) is not offered.
(¹) The counters a clamp may feed (11 to 24) are offered only when the ED3 lists its clamp links in the form a real one gives (ID_Logger_tore: 8 entries, each 0 or a counter id; ID_Logger_tore_neg the same when given): that is how their unit (Wh) was checked. An ED3 that does not give that list, or gives it in another form (another firmware), does not say which counters its clamps feed: counters 11 to 24 are then held, and the status names those holding an index ("C11, C19 not offered: this ED3 does not list the counters its clamps feed in the expected form…"). Nothing is guessed from a list of another form.
(²) The clamp power is the ED3's puissance (mW, published in W, one decimal): on a real ED3 it equals current × voltage × power factor for each clamp (1,455,467 mW for 6.58 A × 235.5 V × 0.94). Its sign is kept: positive in the direction of the clamp's ID_Logger_tore counter, negative in that of its ID_Logger_tore_neg counter. Which direction is consumption or production depends on how the clamp is set up on the ED3: the counter's number and name say it (on a real ED3, a solar clamp produces in the positive direction, towards its production counter C20, and three other clamps have their negative direction towards consumption counters). A clamp listed for one direction only still shows the other one, as a power counted by no counter.
Counters: lifetime indexes, never 0, a drop or a jump held​
The index of a counter is a lifetime meter: Gladys derives the consumption (and its cost) and the production from it; the injection index is shown, Gladys computes nothing from it. The integration passes it through a guard:
  • an index of 0 is never sent;
  • an index that drops, or rises more than a home can draw (100 kW of electricity, 10 m³/h of water, 16 m³/h of gas, plus a small slack), is held back: the last accepted value is sent again, the status says it ("Index held back: C11 (↑ 4072.301 → 14072.301 kWh)"), and it stays held across a restart. Neither time nor repetition makes it accepted;
  • only if it is right (an index reset on the ED3), click "Accept the held index" twice. Gladys counts an accepted jump in full, at once (consumption and cost); an accepted drop is published and nothing is counted for it. After "Attach the devices" to another ED3 whose index is higher, do not accept: delete the counter device and create it again (its history starts over). The first click lists the held values and takes nothing; the second, 3 seconds to 5 minutes later, takes exactly those values (plus what the meter may measure between the clicks), for each counter whose held value has not changed otherwise. Saving the configuration never accepts;
  • the state of the guard is written to /data before Gladys gets the index: if /data cannot be written or read (or does not answer within 5 s), no index is sent, and the status says so;
  • an index is sent once a minute at most.
The guard counts time on the session clock (the wall clock at start, then the time elapsed): a system clock that jumps does not widen its margin. A counter device deleted and created again starts from the value Gladys keeps for it.
Relays: read only unless you list them​
A relay you do not list is read only. To drive one from Gladys, list it in "Relays Gladys may drive", e.g. R1, R2:light (:light makes it a light, a switch otherwise), preferably before creating it in Discover; already created, click "Update" on it in Discover. A switch or a light obeys every "turn everything off" of Google, Alexa, the MCP and the scenes: never list a pump, a freezer, a ventilation, a heating, a door strike nor a valve. Only R1 and R2 can be listed: the X-8R outputs stay read only in this version. A relay removed from the list is read only again at once: its commands are refused, and a switch-off the integration still held for it is dropped (in memory and in /data, after a restart too). Its switch stays on the device in Gladys (without effect): Gladys does not delete a single feature.
The commands go through GET /api/object/ed3/0/SetOnR/<n> and SetOffR/<n> (absolute: never a toggle).
Switching a listed relay off goes before anything​
Switching off a listed relay needs no option and goes before everything else: during a pause after failed reads, with a refused API key, with the command queue full, and before the first read after a restart. Clicked, it cuts any request in flight (a read, a read back, a command, a resend), but another switch-off clicked just before (cut in its turn once it has gone 1 s without an answer).
It is refused only when: the address or the API key is missing; the relay is not listed, or is not R1 or R2; the value is not 0 or 1; the ED3 read is proven to be another one (another MAC address, see "Each ED3 keeps its devices"); the address answers as another GCE box; the slot holds the same ED3 as an earlier slot (see "Several ED3"). Clicked before the configuration is read from Gladys (the API key lives there only, never in /data), it asks Gladys for it at once and waits 3 s; if it has not come, it is kept in memory and sent as soon as the key is known, before anything goes to Gladys; if the relay turns out not to be listed, the status says so. When the ED3 does not take it within 3.5 s (no connection), it is kept (in /data) and sent again as soon as the ED3 is free, before the read backs, by the next reads that show the relay on, and after a restart.
A switch-off the reads do not show is sent again, 3 times at most; then the status says so (check on site). It stays held until a newer command on that relay leaves (your click), or, once applied, another state read twice in a row (changed on the ED3 itself, by its scenarios or its page): never by the time. A switch-on asked before the switch-off and not sent yet is cancelled: nothing leaves after it. A switch-on sent before the switch-off and left without an answer, if the ED3 still applies it within 5 s of its leaving, is no change on the ED3: the switch-off is sent again.
Commands​
A command is written within 3.5 s of the click or refused with "nothing was sent". It is then read back on the ED3: the value asked is a success; the state before is "not applied yet"; no answer in time gives "sent, without confirmation". Two reads follow, 5 s and 20 s later. The commands of a scene are written one after the other, then read back once. One request at a time to the ED3.
Several ED3​
Keep the first one in the top fields, and put the second one in "Eco-Devices 3 #2" (address, API key, its drivable relays), a third one in "Eco-Devices 3 #3". Each has its own devices in Discover ("ED3 #2 · Relay 1 (R1)"), its list of drivable relays and its status on its line. The poll interval and the language are shared; "Accept the held index" applies to all.
Do not change the slot of an ED3 to try another one: the devices already created stay with their slot.
An ED3 goes in one slot only: its counters would be counted twice. A slot with the address of an earlier slot is not read; a slot that reads the same ED3 as an earlier slot (same MAC address, its IP here and its name there, say) is not used, read again every 5 minutes only. Either way, nothing is published for it, no command leaves from it (not even a switch-off: the devices of the earlier slot drive that same ED3), and the status says so. So that the same ED3 is told before anything is offered, a slot after the first reads its ED3, at each start, once the earlier slots have read theirs (or failed, or read nothing: no address, a refused key, a pause): 25 seconds at most, once per start.
Each ED3 keeps its devices​
A device created for an ED3 never gets the values of another ED3 nor drives its relays, even if you change the address of its slot (but the limit below, without a MAC address). The integration keeps, in /data, which ED3 the devices of each slot belong to:
  • by its MAC address when GET /api/system/info gives one (read again every round, kept as a salted fingerprint, never in clear);
  • otherwise by its address and port. Limit: GCE does not document the MAC address (a real ED3, firmware 1.3.0, gives it as macAdress, XX-XX-XX-XX-XX-XX); an ED3 that gives none is not told apart from another one put at the same address, and a change of address needs "Attach the devices".
If the ED3 read is not theirs: no command leaves for it, not even a switch-off; the switch-offs kept for the old one are dropped; none of its values is published onto these devices; Discover is empty for that slot; the status says so.
Then put back the address of their ED3. If you replaced it (or it moved to another address without a readable MAC), click "Attach the devices" twice (within a minute), choosing the slot: its values then go to these devices and its listed relays obey them. The indexes stay guarded: a new ED3 whose counters differ sees its indexes held until you accept them. A slot without any device created simply takes the ED3 it reads.
When the MAC address of an ED3 that gave one cannot be read, only switch-offs leave, and only to the address it was last checked at; if it stays unreadable, "Attach the devices" (two clicks) attaches it by its address: the first MAC address read afterwards becomes its identity, without being compared (you chose it by its address). At start, and after a failed read, its MAC address is read again before anything is sent: the switch-offs kept leave after that check, and a switch-off clicked waits for it 1.5 s at most, then leaves for the address it was last checked at.
If /data is empty while devices exist (deleted, or an installation restored on another machine: the Gladys Plus backup does not hold the data of the integrations), or cannot be read, which ED3 the devices belong to is unknown. Nothing proves it is another one: switch-offs leave, to the address typed; switching on and the values stay refused until "Attach the devices" (two clicks), and the status says so. While /data can be neither read nor written, "Attach the devices" is refused too (it would not be kept). A read or a write of /data that does not answer within 5 s counts as a failure: it holds neither the reads nor the commands.
Pauses and refusals​
A failed read pauses 10 s, 30 s, 1 min, 2 min then 5 min (a minute at least when the ED3 answers 429 or 503), the pause kept across a restart; switching a relay on is refused until the pause ends. An API key refused by the ED3 (401, 403 on its main read) stops the reads until you change the key or "Test the connection" succeeds. A secondary read that fails (counters, names, X-8R, X-THL, system/info), even with a 401, stops nothing: what it gave stays known, without value, and the status says so. While an ED3 cannot be read (or refuses the key), its devices leave Discover; a Scan does not bring them back. They come back with the first read that succeeds.
Limits​
  • Relays R1 and R2, counters, clamps, voltage, X-8R (read only) and X-THL; not the detailed teleinfo frame (apparent power, current tariff), the states of the pulse inputs themselves (the counters they feed are read), the X-8R commands, the schedules, the virtual variables nor Modbus in this version.
  • The clamp power is one signed value (W): Gladys gets no separate production feature; the counters of each direction carry the energy.
  • The integration reads the local HTTP API, not the MQTT of the ED3.
  • Three ED3 at most per integration.
  • http only (the ED3 answers over http on the local network).
Diese Einstellungen fragt Eco-Devices 3 in seinem Konfigurationsbildschirm in Gladys ab.
Your Eco-Devices 3sectionNeinBrings up to three GCE Electronics Eco-Devices 3 into Gladys through their local HTTP API and their API key: the counters (teleinfo, consumption, production, injection, water, gas: lifetime indexes, a jump or a drop held back until you accept it), the power of the current clamps, the mains voltage, the two relays (read only unless you list them below), the X-8R outputs (read only) and the X-THL sensors. Each Eco-Devices 3 keeps its own devices: another one never gets their values nor their commands. Answers recorded on a real Eco-Devices 3 (firmware 1.3.0) and replayed in the tests: counters, clamps, voltage; X-8R, X-THL, gas and tariff indexes not seen there (at 0 or absent); commands not tested on a real device. Not affiliated with GCE Electronics.
Address of the Eco-Devices 3stringJaIts IP address (or name) on your network, without path nor key, with ":port" only if you changed the port of its web server (80); give it a fixed address in your router.
API keysecretJaSet in the Eco-Devices 3 (Configuration menu, API key). The Eco-Devices 3 wants it in the address of every request, over plain http: anyone who can watch your network can read it, as with the Eco-Devices 3’s own page. Kept by Gladys in its database, never shown again, sent only to the Eco-Devices 3, never written in the logs.
Relays Gladys may drivestringNeinThe other relays are read only (the X-8R outputs too, in this version). R1 and R2, the two relays of the Eco-Devices 3; add :light for a light, e.g. "R1, R2:light". A relay listed here obeys every "turn everything off" of Google, Alexa, the MCP and the scenes: never list a pump, a freezer, a ventilation, a heating, a door strike nor a valve. List them before creating them in Discover; a relay already created stays read only until you click "Update" on it in Discover.
OptionssectionNeinShared by every Eco-Devices 3 of this integration.
Read every (seconds)numberNeinHow often the Eco-Devices 3 is read: 15 s by default, 10 s at least. The counter indexes go to Gladys once a minute at most.
Language of the namesselectNeinUsed for the names of the devices and features added from now on.
Eco-Devices 3 #2 (optional)sectionNeinAnother Eco-Devices 3 of the house (never the same one as above: refused, its counters would be counted twice), with its own devices: fill in its address and its API key; leave empty otherwise. Never move an Eco-Devices 3 from one slot to another: its devices stay with their slot. The options above are shared.
Address of Eco-Devices 3 #2stringNeinIts IP address (or name) on your network, without path nor key, with ":port" only if you changed the port of its web server (80); give it a fixed address in your router.
API key of Eco-Devices 3 #2secretNeinSet in the Eco-Devices 3 (Configuration menu, API key). The Eco-Devices 3 wants it in the address of every request, over plain http: anyone who can watch your network can read it, as with the Eco-Devices 3’s own page. Kept by Gladys in its database, never shown again, sent only to the Eco-Devices 3, never written in the logs.
Relays of Eco-Devices 3 #2 Gladys may drivestringNeinSame rules as for the first one (R1, R2, :light for a light). A relay listed here obeys every "turn everything off": never list a pump, a freezer, a ventilation, a heating, a door strike nor a valve.
Eco-Devices 3 #3 (optional)sectionNeinAnother Eco-Devices 3 of the house (never the same one as above: refused, its counters would be counted twice), with its own devices: fill in its address and its API key; leave empty otherwise. Never move an Eco-Devices 3 from one slot to another: its devices stay with their slot. The options above are shared.
Address of Eco-Devices 3 #3stringNeinIts IP address (or name) on your network, without path nor key, with ":port" only if you changed the port of its web server (80); give it a fixed address in your router.
API key of Eco-Devices 3 #3secretNeinSet in the Eco-Devices 3 (Configuration menu, API key). The Eco-Devices 3 wants it in the address of every request, over plain http: anyone who can watch your network can read it, as with the Eco-Devices 3’s own page. Kept by Gladys in its database, never shown again, sent only to the Eco-Devices 3, never written in the logs.
Relays of Eco-Devices 3 #3 Gladys may drivestringNeinSame rules as for the first one (R1, R2, :light for a light). A relay listed here obeys every "turn everything off": never list a pump, a freezer, a ventilation, a heating, a door strike nor a valve.
So installierst du Eco-Devices 3 in Gladys​
  1. Öffne in Gladys Integrationen: Eco-Devices 3 erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/lm1lc3n7/gladys-ecodevices-ed3:0.2.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-ecodevices-ed3.
Eco-Devices 3 benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Eco-Devices 3 ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
