De Dietrich Smart-Home-Integration, kostenlos und Open Source
De Dietrich-Integration für Gladys Assistant
Control your De Dietrich heating, hot water and boiler sensors via the De Dietrich cloud.
Control your De Dietrich connected heating system from Gladys Assistant, through the De Dietrich cloud (the same service used by the De Dietrich mobile app, powered by the BDR Thermea platform).
Features​
  • Heating (climate zones) — read the room temperature and read/set the target temperature of each heating zone. Setting a temperature applies a temporary override when the zone follows its schedule, or switches it to manual mode otherwise, exactly like the app.
  • Domestic hot water (DHW) — read the current water temperature and read/set the comfort setpoint of each hot-water zone.
  • Boiler sensors — read the outdoor temperature and the water pressure of the appliance.
  • Energy consumption — read the cumulative heating and domestic-hot-water energy consumed (in kWh), when the appliance reports it. These are meter-style indexes that feed the Gladys energy graphs.
  1. Install the integration from the Gladys integrations store.
  2. Open its configuration and fill in the email and password of your De Dietrich account (the same credentials you use in the De Dietrich mobile app).
  3. Go to the Discovery tab and start a scan: your heating zones, hot-water zones and boiler appear and can be added to Gladys.
Your devices are polled once per minute. Heating and hot-water setpoints you change from Gladys are sent straight to the De Dietrich cloud.
Notes​
  • This integration talks to the De Dietrich cloud, so an internet connection and a working De Dietrich account are required.
  • Your credentials are stored encrypted by Gladys and are only used to authenticate against the De Dietrich cloud.
Diese Einstellungen fragt De Dietrich in seinem Konfigurationsbildschirm in Gladys ab.
De Dietrich emailstringJaThe email address of your De Dietrich account.
De Dietrich passwordsecretJaThe password of your De Dietrich account.
So installierst du De Dietrich in Gladys​
  1. Öffne in Gladys Integrationen: De Dietrich erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/callemand/gladys-dedietrich:1.0.0) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/callemand/gladys-dedietrich.
De Dietrich benötigt Gladys >=4.62.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
De Dietrich ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von callemand veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
