Daikin Airbase Smart-Home-Integration, kostenlos und Open Source
Daikin Airbase-Integration für Gladys Assistant
Daikin ducted air conditioning via a local Airbase (BRP15B61) adapter: mode, temperature, zones.
Controls Daikin ducted air conditioning fitted with an Airbase (BRP15B61) Wi-Fi adapter, directly on your local network — no Daikin account or cloud.
Features​
  • Power, Mode (auto, cool, heat, dry, fan), Target temperature and Fan speed (auto, low, mid, high).
  • Indoor temperature, and Outdoor temperature when the unit reports it.
  • One switch per zone, named as in the Daikin Airbase app.
  1. In your router, give the adapter a fixed IP (DHCP reservation).
  2. Enter that IP in the Configuration tab (several adapters: separate with commas).
  3. Open the Discovery tab and create the device.
  • No Airbase adapter answered — check the IP, and that http://<ip>/skyfi/common/basic_info opens in a browser on the same network.
  • Changes from the wall controller appear after the refresh interval (30 s by default).
  • Logs: docker logs on the integration container.
Diese Einstellungen fragt Daikin Airbase in seinem Konfigurationsbildschirm in Gladys ab.
Airbase adapterssectionNeinThe adapter is reached directly on your network, no Daikin account needed. Give it a fixed IP (a DHCP reservation on your router) so it keeps the same address.
Adapter IP address(es)stringJaOne or more, separated by commas, e.g. 192.168.1.50
Refresh interval (s)numberNeinHow often the adapter is read; changes made from the wall controller or the Daikin app appear within this delay.
So installierst du Daikin Airbase in Gladys​
  1. Öffne in Gladys Integrationen: Daikin Airbase erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
  2. Klicke auf Installieren. Gladys lädt das Docker-Image (ghcr.io/plsoftware/gladys-daikin-controller:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration).
  4. Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/plsoftware/gladys-daikin-controller.
Daikin Airbase benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Daikin Airbase ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von plsoftware veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
