California grid (CAISO) Smart-Home-Integration, kostenlos und Open Source
Unofficial. California grid (CAISO): wholesale prices, demand, renewables, CO2, Flex Alert.
Unofficial integration. It reads the public files of the California Independent System Operator (CAISO), the operator of most of the California grid, without account nor key, and publishes in Gladys:
- the grid: demand and net demand (MW), renewables share (%), carbon intensity (g/kWh), CO2 emissions (t/h), the grid conditions published by the ISO (Normal, Flex Alert, EEA...) and an alert level from 0 to 6;
- the real-time wholesale prices of the three trading hubs NP15 (Northern California), SP15 (Southern California) and ZP26 (Central California), in $/MWh, 5-minute intervals.
Wholesale prices are not your retail rate. They are the prices of the market where the ISO balances the grid (locational marginal price, LMP). Your utility bills you a retail rate (PG&E, SCE, SDG&E...) that does not follow them minute by minute. Use them as a signal (cheap, often negative, when solar floods the grid), not as a bill.
Tried against the real CAISO files (Today's Outlook and OASIS) on 2026-10-30, and in the Gladys sandbox; never tested with a real Gladys at home, and never seen during a real Flex Alert or EEA (see "Grid conditions").
Setup
- Install the integration from the store, open its page.
- Pick the language of the texts, the read interval (5 to 60 minutes, 5 by default: the ISO updates both sources every 5 minutes) and, if you want the scene trigger, the low price threshold.
- In the Discovery tab, create the devices you want: the grid, and one or more hubs. A source is only read while a device needs it: the grid needs Today's Outlook, a hub needs OASIS. Nothing is read before.
Devices
| Feature | Unit | From |
| Demand | MW (in name) | CurrentSystemDemand, with its own time |
| Net demand (minus wind, solar) | MW (in name) | CurrentNetDemand, with its own time |
| Renewables share | % | renewablesPercent (above 100 %: 100) |
| Carbon intensity | g/kWh | currentCo2intensity (t/MWh × 1000, exact) |
| CO2 emissions | t/h (in name) | currentCo2 |
| Alert level | 0 to 6 | the grid conditions, see below |
| Grid conditions | text | the words of the ISO, as published |
| Data status | text | time of the reading, or why nothing is shown |
The renewables share is the one the ISO publishes: renewables (solar, wind, geothermal, biomass, biogas, small hydro; large hydro excluded, as in California's rules) over the demand. When renewables exceed the demand (the rest exported or stored), all the electricity consumed is renewable: 100. The carbon intensity and the emissions are the ISO's CO2 figures (imports included), not CO2-equivalent.
The demand values are not energy sensors: a whole grid is not a home meter,
and they never enter the energy dashboards of Gladys.
CAISO wholesale price NP15 / SP15 / ZP26
| Real-time wholesale price | $/MWh | OASIS PRC_INTVL_LMP, market RTM, hub LMP |
| Data status | text | the 5-minute interval shown, or why not |
One OASIS query reads the three hubs at once (the ISO allows one request every 5 seconds; the integration never sends two less than the interval apart). The answer always holds the interval running, and at times the next one when the ISO has already settled it: such a next interval is published at its start, without a request. A price is shown for 10 minutes after its interval ends: with a read interval of 30 to 60 minutes, the price is "stale" most of the time; keep 5 minutes (the default) for the prices.
Freshness: nothing old shown as new, never 0 for an unknown
- A value is published once per reading of the source, only while it is
fresh: a reading of Today's Outlook at most 20 minutes old (its own
time, turned into UTC with the Last-Modified of the file), a price whose
interval ended at most 10 minutes ago (OASIS times are UTC). The age is
counted from the server time plus the
Agea cache (CloudFront) adds: a copy kept for hours by a cache is stale, never fresh. - A missing, unreadable, out of range or stale value is never published, and never as 0: the "Data status" text and the integration status say so ("Stale, nothing published: last reading of 10/29 22:55 PDT", "not published: demand"). The texts are updated when a reading turns stale even without a new read.
- After a restart, nothing is published before a new reading (a reading already published before the restart is never sent again).
- Times are Pacific times (the ISO's), turned into UTC exactly across the changes of time, shown with PDT or PST (the hour repeated in November reads twice, told apart); in that hour, a time without the Last-Modified of its file is unreadable (never a guess).
Grid conditions and alert level
The grid conditions are the gridstatus list of stats.txt. The ISO's
Today's Outlook page no longer shows this field (since November 2023 it
shows the notices of another service, not documented as an open feed): it is
still in the file, but it may lag behind a notice, or miss it. The
reference for the emergency notices is the ISO's page
https://www.caiso.com/emergency-notifications. The status says it.
Each entry is matched whole (case and spaces ignored, "EEA 1" or "EEA1"; a comment after a dash, as in "EEA 3 - Load shed", is ignored, unless it starts with a word saying the notice ended: "- cancelled", "- expired"...) against the seven notices of the ISO and "Normal":
| Level | Conditions |
| 0 | Normal |
| 1 | Restricted Maintenance Operations (RMO) |
| 2 | Flex Alert |
| 3 | EEA Watch (Energy Emergency Alert Watch) |
| 4-6 | EEA 1, EEA 2, EEA 3 (Energy Emergency Alert 1, 2, 3; EEA1…) |
| none | Transmission Emergency (alone in the list: 0) |
The level is the highest entry recognized: on 6 September 2022 the list "EEA 3, EEA 2, EEA 1, EEA Watch, Flex Alert, Restricted Maintenance Operations, Transmission Emergency" gives 6. "Transmission Emergency" is a regional notice: it is shown in "Grid conditions" and never raises the level; alone in the list (nothing but Transmission Emergency), the level is 0, so that the level does not stay at an old EEA. An entry not recognized (a new wording, or one saying the notice ended, as "EEA 3 cancelled") is left out of the level and named in the status: the level published is then a minimum, and may be below the real one (an unrecognized entry could be a higher notice). Level 0 needs every entry recognized: "Transmission Emergency" or "Normal" next to an entry not recognized ("EEA-3, EEA-2, Transmission Emergency") gives an unknown level, never 0: an entry not recognized never brings the level back to normal, nor fires "back to normal". When the level is unknown (no entry carrying a level, or 0 next to an entry not recognized), it is not published and "Grid conditions changed" does not fire: Gladys keeps showing the last level published, the "Grid conditions" text and the status say what the ISO wrote, and the status names the entries not recognized.
Scene triggers
- Low wholesale price (CAISO): a hub price went below the "Low price
threshold" of the configuration (
phase=started), or came back at or above it (ended). Filters: the hub, the phase. Variables: hub, phase, price, threshold. Only for a hub whose device is created. - Grid conditions changed (CAISO): the alert level changed (
level,previous_level,conditions= the words of the ISO). Filter: the new level. Only while the grid device is created.
Each fires once per change, on a fresh reading only. The first value seen after the installation (or after a new threshold) is a reference, never an event; the last state is kept in /data, so a restart never fires a trigger again. An unknown level, or a stale reading, is never a change. An event that Gladys does not accept is sent again with the next reading if the change still holds.
For a condition on the value itself ("price below X while..."), the price feature works with the usual device triggers of Gladys.
Pace, errors and status
- Each source at its own pace: never two requests less than the interval apart (kept across restarts), one request at a time, an honest User-Agent, the ETag and Last-Modified of Today's Outlook sent back (a 304 keeps the reading and its age). The Discovery tab, a device updated, a reconnection to Gladys send no request; saving the form sends one only if a shorter interval makes a source due; a device created sends one only when its source was not asked within the interval.
- HTTP 429 or 5xx: the source pauses 5 minutes, doubled at each new refusal,
from 60 seconds to 6 hours,
Retry-Afterhonoured; kept across restarts; the other source goes on. It is read again right when the pause ends. - The status is "connected" only when a source answered and holds fresh data (right after a restart, before the first read is due: when a source read fine within the interval before the restart). It lists, in English and French: the source unreachable, paused (also right after a restart, with its cause), refused, stale, values not published, conditions not recognized (quoted), OASIS "no data" or an OASIS error code, /data not readable, not writable or not answering, where the alert level comes from, and "prices are wholesale market prices, not your retail rate".
getConfigfailing at a connection to Gladys: tried again after 5 s, doubled up to 5 minutes, without end; the status says so.- /data (the pace, the pauses, what was published, the trigger states): each wait is bounded (5 s), one save at a time (a save that hangs is said, and the next ones fold into one instead of piling up); a file that cannot be read is set aside, never overwritten, and said (and if it cannot even be set aside, nothing is written to /data). While /data cannot be written (said in the status), all of this lives in memory only: a restart then reads at once, may publish the last reading again and may fire a trigger again; the promises about restarts above hold only while /data can be written.
Sources and limits
- Today's Outlook:
https://www.caiso.com/outlook/current/stats.txt. - OASIS:
https://oasis.caiso.com/oasisapi/SingleZip(public interface, documented by the ISO, no key). - Data © California ISO. This integration is not affiliated with nor endorsed by the California ISO.
- Read-only: the integration only sends GET requests.
Diese Einstellungen fragt California grid (CAISO) in seinem Konfigurationsbildschirm in Gladys ab.
| California grid (CAISO) | section | Nein | Reads the public files of the California ISO, without account nor key: Today's Outlook (demand, renewables share, CO2, grid conditions such as Flex Alert) and OASIS (real-time wholesale prices of the NP15, SP15 and ZP26 hubs). Create the devices you want from the Discovery tab: a source is only read while a device needs it. Wholesale prices are not your retail electricity rate. |
| Language of the device texts | select | Nein | Language of the device names and status texts. |
| Read interval (minutes) | number | Nein | Time between two reads of each source, 5 to 60 minutes. The ISO updates both every 5 minutes. |
| Low price threshold ($/MWh) | number | Nein | The "Low wholesale price" scene trigger fires when a hub price goes below this value, and again when it comes back at or above it. 0 = negative prices. |
So installierst du California grid (CAISO) in Gladys
- Öffne in Gladys Integrationen: California grid (CAISO) erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/lm1lc3n7/gladys-caiso:0.1.1) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/LM1LC3N7/gladys-caiso.
California grid (CAISO) benötigt Gladys >=5.3.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
California grid (CAISO) ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von LM1LC3N7 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
