Atlantic Cozytouch Smart-Home-Integration, kostenlos und Open Source
Control Atlantic Cozytouch air conditioners and heat pumps (Takao M3) in Gladys Assistant.
Controllable modes
Besides mode, target (heat and cool) and swing: eco, boost, silence, presence/away and weekly program — the same capabilities as the Home Assistant integration. This integration brings Atlantic air conditioners and heat pumps controlled by Cozytouch (Takao M3 and other connected Atlantic equipment) into Gladys Assistant.
What it does
One device per controllable room of the Cozytouch account, with: on/off switch, mode select (off, heating, cooling, auto, fan), writable target temperature (heating or cooling capacity follows the current mode), room temperature sensor with history, state text, and a fan speed select (Auto/Low/Medium/High) when the equipment exposes it.
Prerequisites
- A Cozytouch account that works in the Atlantic app on your phone.
- Gladys Assistant 5.1 or later.
Setup
- Install the integration from Integrations in Gladys.
- In the Configuration tab, enter the Cozytouch e-mail and password, then click Test the connection: the number of controllable rooms is shown.
- Open the Discovery tab and create the rooms you want.
If a room is missing from discovery, find its numeric id (magellan deviceId in the app's developer tools) and enter it in the “Room id” field.
The integration talks to the Atlantic Magellan cloud over the Internet, like the official app; your credentials stay in the Gladys configuration (secret field).
- “0 controllable room(s) found”: check the credentials; for accounts with several installations, use the “Room id” field.
- The heating and cooling setpoints are a single feature in Gladys: the integration writes the capability matching the current mode.
Unofficial community integration, not affiliated with Groupe Atlantic.
Diese Einstellungen fragt Atlantic Cozytouch in seinem Konfigurationsbildschirm in Gladys ab.
| Getting started | section | Nein | Use the e-mail and password of your Cozytouch account (the same as the Atlantic Cozytouch app). The integration talks to the Atlantic Magellan cloud, exactly like the official app. Unofficial integration, no affiliation with Atlantic. |
| Cozytouch e-mail | string | Ja | |
| Cozytouch password | secret | Ja | |
| Room id (optional) | number | Nein | Leave empty for automatic discovery. If a room is missing, find its numeric id in the Cozytouch app (magellan deviceId) and enter it here. |
| Labels language | select | Nein | |
| Refresh interval (s) | number | Nein | How often the rooms are read, in seconds (one minute minimum, to stay courteous with the Atlantic cloud). |
So installierst du Atlantic Cozytouch in Gladys
- Öffne in Gladys Integrationen: Atlantic Cozytouch erscheint im Katalog neben den nativen Integrationen, mit einem Community-Badge.
ghcr.io/tchoinard38/gladys-atlantic-cozytouch:1.2.0) herunter, startet es in einer vom Kern isolierten Sandbox und erzeugt die Oberfläche der Integration (Geräte, Erkennung und Konfiguration). - Öffne den Bildschirm Konfiguration der Integration, fülle die Einstellungen aus und speichere.
- Du kannst sie auch direkt über die URL ihres Repositorys installieren: https://github.com/tchoinard38/gladys-atlantic-cozytouch.
Atlantic Cozytouch benötigt Gladys >=5.1.0. Der Katalog in Gladys wird stündlich aktualisiert, eine neue Version ist also spätestens eine Stunde nach ihrer Veröffentlichung verfügbar.
Atlantic Cozytouch ist eine externe Integration: eine Community-Integration, die als Docker-Container verpackt und auf GitHub veröffentlicht wird. Gladys installiert sie mit einem Klick und führt sie in einer vom Kern isolierten Sandbox aus. Sie wird von tchoinard38 veröffentlicht und gepflegt, nicht vom Gladys-Kernteam.
