Gladys Assistant 4.4 is available with zone detection
· 3 min read
Hi all,
Today we are releasing Gladys Assistant v4.4, a brand new version that is finally making the map view useful in Gladys !
What's new in Gladys Assistant 4.4?
Create zones in the map view
On the map, you can now create zones:
  • For your home
  • Your work
  • The school
  • Literally anywhere on earth!
Create a zone
You should see your created zone on the map
Map
You can of course edit those zones:
Edit a zone
Start a scene when a user enters/leaves a zone
Now, using the zones you previously created, you can now create a zone that will be trigger when a user enters the zone:
User entered zone in scene
or when the user leaves the zone:
User left zone in scene
An example: set your user as "at home" or "left home"
Imagine you want to set your user as "at home" when you enters a zone, and "left home" when you leaves a zone.
You can do that by creating two scenes, at home:
At home
And left home:
Left home
House empty/not empty condition in scene
It was already possible to create a scene that triggers when a house is empty/not empty, but it was not possible to add a condition in a scene to continue only if the house is empty/not empty.
It's now possible!
House empty
House not empty
With this scene, you can add the presence card on the dashboard:
User presence dashboard
Bugfixes
We fixed a few bugfixes in this release:
  • Calling a scene from a scene should duplicate the scope object to avoid context pollution #1205
  • Fix log in scene continue-only-if action #1201
How to upgrade?
Thanks to contributors
Thanks to everyone who contributed to this release and gave their feedback on the forum!
If you want to talk about this release, you're all welcom on the forum !
