Gladys 4.80: Matter 1.5, Netatmo, Tuya & a More Powerful AI Agent πŸš€
Β· 3 min read
Hey everyone!
Lots of new things lately πŸ˜€ This version 4.80 brings many stability improvements, fixes for Matter, Netatmo, and Tuya, plus several AI additions.
πŸ€– AI​
The AI agent keeps improving, with two new features:
  • βž• Added a new sensor.set-state tool, letting the agent directly change the state of certain sensors when asked. For example, you can use the AI to read a camera image looking at a meter and store the value it reads into a virtual device. You could also automatically read a license plate and store the number into a virtual device!
  • 🐞 Added a button to download the AI's debug context as JSON, to make it easier to diagnose issues and share them with the community.
The AI-generated weekly reports now appear in the background tasks (Settings β†’ Tasks), which lets you track their execution and easily spot any errors. A random delay was also added before they're generated, to avoid overloading the servers all at once.
🏠 Matter​
This version further improves Matter compatibility:
  • 🌑️ Added local temperature reporting on compatible devices.
  • πŸ”„ More robust connection process.
  • πŸ“ Richer logs to make debugging easier.
  • πŸŒ€ Several fixes for Matter fans.
  • πŸŽ›οΈ Fixed a bug where a device's unique identifier changed when it was updated.
  • ⚑ Reads the initial state of device features at startup.
  • ❗ Errors when registering a device are now shown directly in the interface.
Matter.js was also updated to version 0.17.3, a major step forward bringing notably:
  • Support for the Matter 1.5 / 1.5.1 specification, improving compatibility with the newest devices.
  • A 20-50% reduction in memory usage, letting Gladys run even more smoothly.
πŸ“‘ Integrations​
Tuya​
The Tuya integration keeps maturing: a new common mapping layer to improve device handling in both local and cloud modes, and an assistant to automatically create a GitHub ticket when a device is partially or not supported.
Netatmo​
Two important improvements: restored automatic OAuth token refresh, and a more resilient automatic reconnection in case of authentication errors, including during business API calls.
Zigbee2MQTT​
Zigbee devices now display their IEEE address as well as a direct link to open the device in Zigbee2MQTT, making diagnostics and configuration easier. Remember to add your Zigbee2mqtt interface URL in the settings to use this feature πŸ˜‰
πŸ› Fixes​
  • Fixed a bug on scenes using the next sunrise trigger.
  • Fixed an issue preventing a device from being saved when energy_parent_id was invalid.
❀️ Thanks to the contributors​
A big thank you to everyone who took part in this release: @cicoub13, @Terdious, and @Will_71. And thanks to the whole Gladys community for your feedback, tests, and contributions that keep the project moving forward quickly! πŸš€
As always, Gladys updates automatically within 24 hours if you use Watchtower, or you can do it in one click from the settings. See the full release notes.
