Gladys 4.74: Sunrise & Sunset Offsets in Your Scenes ☀️
· One min read
Hey everyone,
A new version of Gladys Assistant is available, with several fixes and improvements around Matter, Zigbee2MQTT, and sun-based scenes ☀️
✨ New features
🌅 Offset before/after sunrise and sunset
You can now configure a delay before or after sunrise and sunset in your scenes. A few example use cases:
- Turn the lights on 30 minutes before sunset
- Close the shutters 15 minutes after sunset
- Trigger a scene before sunrise
Thanks @cicoub13 for this contribution 🙌
💡 Zigbee2MQTT: Philips Hue Dimmer Switch v2 added
Support for the Philips Hue Dimmer Switch v2 remote has been added in Zigbee2MQTT. You can now easily use it in your Gladys scenes and automations.
🛠 Fixes
- Matter: fixed a 409 error on some devices. Fixed an issue that could cause a
409error when updating Matter devices sharing the same unique identifier. - Gladys Plus: fixed an association bug on first login. Fixed an issue that could prevent a user from being correctly associated with Gladys Plus on first login.
Gladys updates automatically, or you can do it in one click from the settings.
👉 See the full changelog on GitHub. Thanks to all the contributors!
