Gladys 4.73: Major Matter.js Upgrade, Local Tuya & MCP Server
Β· 2 min read
Hey everyone πŸ‘‹
A new version of Gladys Assistant is available: v4.73.0! This release brings several important improvements around energy, Matter, Local Tuya support, and the Airplay integration.
🧩 Matter.js updated to 0.16.11​
Gladys now ships the latest version of Matter.js (0.16.11). This is a big update, we're moving up from 0.13.0, and it improves the compatibility and stability of Matter devices.
Please check that your Matter devices still work after this update, as there's a Matter.js file migration that was a little tricky for some users.
➑️ Pull request #2501
πŸ”Œ Local Tuya: the first foundation​
This first PR lays the groundwork for Local Tuya support in Gladys, which will eventually let you control some Tuya devices locally, without relying on the cloud. Thanks @Terdious!
➑️ Pull request #2434
⚑ Energy management & MCP optimization​
This version adds new energy features and improves the performance of the MCP (Model Context Protocol) used by AI clients. Thanks @bertrandda!
➑️ Pull request #2522
πŸ”Š AirTunes library replaced​
The airtunes library has been replaced by airplay-sender to improve the stability and maintainability of the Airplay feature. Thanks again @bertrandda!
➑️ Pull request #2439
As usual, you can update Gladys directly from the interface, or simply wait for it to update on its own. Thanks to all the contributors πŸ™Œ
πŸ”— Full changelog
