Gladys 4.72: Faster AI, Rock-Solid HomeKit & Plenty of Fixes
Β· 2 min read
Hey everyone!
Gladys Assistant 4.72.0 is available π, with a faster AI, a more stable HomeKit, and a long list of fixes.
β¨ New featuresβ
- Zigbee: dual on/off support for the IKEA BILRESA button. The IKEA BILRESA button is now fully supported via Zigbee2mqtt.
- AI: lower latency and cost. Camera images sent to the AI are now resized before sending, which reduces both the latency and the cost of API calls.
- Integration list: tags added. Integrations are now tagged (local, cloud, Gladys Plus) to make their operating mode clearer.
- ZwaveJS UI: out of alpha. The ZwaveJS UI integration is stable enough, the alpha warning banner has been removed.
- MQTT: renamed to "MQTT Virtual Devices" to make the integration easier to understand for users coming from Home Assistant.
- Node-RED: warning before container deletion. A message now warns that deleting the Node-RED container also deletes all associated data.
π Bug fixesβ
- HomeKit: fixed high CPU usage related to mDNS. A bug caused abnormally high CPU usage. It's fixed by offering several mDNS options.
- Nuki: fixed handling of Home Assistant discovery messages. The integration was listening too broadly, which caused performance issues when many Home Assistant-compatible devices shared the same broker.
- CalDAV: configuration errors are now displayed directly in the interface.
- Backup restoration: more robust. Security was hardened in the Gladys Plus backup restore function, notably by using
execFilefor OpenSSL commands. - User account creation: the text above the "email" field is now clearer.
- Zigbee2mqtt: fixed an energy tracking bug where devices with energy features were always shown in the "Discovery" tab.
- Energy monitoring: fixed a bug when deleting a meter in the Zigbee2mqtt integration.
- Matter: fixed color handling by using a numeric bitmap for
optionsMaskin Matter color control.
Thanks to all the contributors for this release: @bertrandda, @cicoub13, and @David-Digitis.
To update, you can wait 24 hours or go to Settings β System β Update. Happy Easter weekend, everyone! π
