Camera live streaming in Gladys Assistant 4.23
ยท 3 min read
Hi everyone!
I'm happy to present you today Gladys Assistant 4.23, a new release with lots of new features!
Live streaming cameraโ€‹
The major feature of this version is the ability to watch your cameras live on the dashboard, either locally or remotely via Gladys Plus.
Camera streaming
The video stream is encrypted from end to end before guaranteeing your privacy, as always ๐Ÿ˜‰
Note: This feature requires quite a lot of resources (playing a video stream, compressing it, encrypting it, live, it requires resources!), if the live doesn't start or takes really too long to start, it might be that your machine is not powerful enough for it. 32-bit Raspberry Pi's are not powerful enough for this, for example.
Selecting the Zigbee dongle modelโ€‹
In the Zigbee integration, it is now possible to select which Zigbee dongle model you are using, which will update the Zigbee2mqtt configuration file automatically!
Zigbee model
Thanks to AlexTrovato for the development ๐Ÿ‘
Calculations in scenesโ€‹
In scenes, it is now possible to do mathematical calculations in 2 places:
In the "continue only if" condition, it is possible to compare several variables with each other, while doing a mathematical calculation:
Continue only if with calculation
In the action "control a device" it is possible to use a variable and a mathematical calculation to deduce the value that will be sent to the device.
Control a device with calculation
Very useful to make dynamic scenes that adapts to the execution of the scene!
Thanks @bertrandda for the development ๐Ÿ‘
NextCloud Talk integrationsโ€‹
New integration! This integration allows you to use NextCloud Talk to chat with Gladys, the same way the Telegram integration works.
NextCloud Talk
Various improvements and fixesโ€‹
  • Improved account creation process: more responsive, simpler, with less information to fill in.
  • Homekit integration now supports door/window opening sensors
  • The dashboard displays the sensor names in a clearer way (#1749)
  • Fixed a bug on the "HTTP Request" action that did not allow to have an empty POST request body (#1772)
How to upgrade?โ€‹
Thanks to contributorsโ€‹
Thanks to everyone who contributed to this release and gave their feedback.
If you want to talk about this release, you're all welcome on the forum!
Support usโ€‹
If you want to support us, there are many ways:
  • Answer posts on the forum, give your feedback.
  • Help us improve the documentation.
  • Develop new features/integrations on Gladys, we are 100% open-source.
  • Subscribe to Gladys Plus.
Emails are sent by Pierre-Gilles Leymarie, founder of the project. You can unsubscribe at any time ๐Ÿ™‚
